Question about Lionel New York Central Flyer
Lionel new york central flyer smoke won't work
Added smoke fluid, smoke switch on engine is set to on. Engine will not blow smoke.
2 Suggested Answers
  • 34 Answers
SOURCE: Purchased a Lionel New York
The magnet may not have enough punch using track power. Recommend you use an aux power source fixed 10 to 13VAC supply and not track power. There may also be a slight + difference between the track magnet head and the plate on the coal car so that there is insufficient force to release the dump mechanism.
Posted on Sep 05, 2011
Lionel 6-5960 sound activation instructions
Contact Lionel Customer Service: 586-949-4100
Mar 05, 2014 | Lionel New York Central Flyer
Lionel # 3830 submarine instructions for assembly
You can download instructions and product manuals at Lionel.com in their customer service section. If you don't find what you need, use the Contact Us link to ask for help. Lionel offers great customer support.
Mar 03, 2014 | Lionel New York Central Flyer
Car will only go in one direction
please provide more information:
control system used.
locomotive or set number
Jan 29, 2014 | Lionel New York Central Flyer
Www support toys1628 com
Check that you have added the smoke fluid (oil) to the engine and that it has not run dry. The smoke from the engine is generated by a small chamber with a heating element built in. The heating element gets hot as the loco runs and heats the smoke fluid up which in turn creates the steam/smoke. If there is no fluid the heating element can over heat and will smell as you describe. Not sure if your model has a smoke effect on/off switch, if it has switch it off if you do require the smoke effect.
Dec 27, 2013 | Northpole Lionel North Pole Steam Engine...
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Jan 05, 2013 | Lionel New Haven Freight Train Set
How can I fix smoke problem on polar express
Most Lionel engines have a small slider switch which can turn off the smoke generator. Check to see that the switch is in the ON position. Check the engine manual (available from Lionel's website) for the location of the switch.
Also, if the smoke generator is always on and no fluid had been used in the generator, it will eventually burn out. Replacement smoke generators are available from Lionel.
Jan 05, 2012 | Lionel The Polar Express Train Set
The train sounds on my New York Central Flyer model #6-30016 won't turn off. How do I turn the sounds off?
The set instructions don't list a way to turn the sounds off. If there is no switch on the underside of the tender or a volume control (looks like a slotted screw), you may not be able to turn the sounds off. Contact customer service at Lionel.com or give them a call for a prompt answer.
Jul 23, 2011 | Toys
Purchased a Lionel New York Central Flyer Operating Freight Expansion Pack with a coal dumper. My set runs on O-gauge track, not fas track, but the magnet operation appears to be the same. The coal...
Apr 22, 2011 | Lionel New York Central Flyer
Lionel New York Central Flyer Logo
138 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
