Question about Bernina Activa 130
Bernina 740 favorit timing
Bought this machine used several years ago. Has always had a tendency to freeze up on me. This time I looked and found thread all caught up in the bobbin. Removed as much as possible but there was thread caught up underneath the bobbin case. Took the bobbin case off and was finally able to remove all of the thread. (I know, "Stupid move) Then continued looking to figure out why it froze. Somehow the cord was placed incorrectly and when positioned just right would actually catch on the gears. Fixed that, put machine back together, but can"t seem to get timing right. Local dealership is more interested in selling me a new machine than fixing the one I have. Any help or ideas is greatly appreciated
Boscados 740 840 940 742
Posted on Mar 05, 2009
My mother-in-law of 88 years has lost her bobbin case for her Bernina Favorit 740.She still sews profusely! Where can I get another one? Many thanks. Toni
Posted on May 28, 2011
I inhereted a bernina ferreit in cabinet need instruction manual
I believe you probably have a Bernina Favorit. A Favorit is an early mechanical Bernina sewing machine and, to Bernina vintage lovers, is a keeper. Favorits are the flat-bed version, not the free-arm version, but is a wonderful machine nonetheless. If you search the internet using:
Brand +
Model +
the word "Manual"
(ie Bernina 640 Manual)
you might have some luck finding a manual.
Or, you can join the Yahoo BerninaThirtySomethings group
Yahoo Groups, where older manuals are available in the Files section. In addition, you will have access to a wonderful resource of Bernina users/lovers including conversations on using, maintaining, repairing, and assorted other advice about your older Bernina.
The first thing you should probably do is pick up a good quality sewing machine oil (Bernina oil for CB Hook is recommended--however, never use 3-in-1, WD-40, cooking oil, or the old oil can that you might find in the machine's accessory box). Consult the owner's manual in the Maintenance section to clean and oil your machine. If the machine has not been used in several years, the motor may sound like it is straining to move the mechanical parts. Most likely, the old oil has dried out and is sticking things together. Do not force the motor to move things without first cleaning and oiling the machine.
Remove the top cover and swing open the cover on the left side where the lightbulb is located. Gently hand rotate the handwheel and while watching the moving metal parts, apply ONLY one-two drops of oil every place that metal rubs against metal. (Sometimes the oil ports are marked with red paint as a guide, but some machines are not marked.) Use only 1-2 drops at a time. Do NOT over-oil as too much oil can be as damaging as no oil. Gently move all the levers and dials and oil those moving parts as well. Do NOT oil the white plastic gears, the belt, or the large round metal cams (which your machine may or may not have). Then, tilt your machine back and remove the bobbin & bobbincase and with a soft brush, remove any lint, dust. Then while hand-rotating the handwheel and moving the levers and knobs, apply oil to the moving parts under the machine. The feed dogs are usually a problem so be sure to test the feed dog knob. If anything seems to be sticky, resistant to movement, you can also direct hot air from a handheld hairdryer into the interior mechanism to help loosen things. Be sure to place a drop of oil on the bobbin hook in the bobbin area (the manual should show this).
If there is anything that is still sticky, then a few more drops of oil and the handheld hairdryer should be employed until things are moving well again.
A Bernina is a great machine for the sewing enthusiast, but only if it is maintained and cared for regularly. Cleaning and oiling should be performed approximately every 8-12 hours of constant sewing, or every time a bobbin is emptied, or at least every six months if not in frequent use.
Aug 30, 2015 | Bernina Sewing Machines
I'm trying to get my Grandmother's Bernina Favorit 740 running again. I cannot get the zigzag lever to pull down so buttonholes can be made. Any suggestions?
The lever could be rusted in place; ie. the parts that move across/over each other when the lever tries to move down, don't.
Here is a list of Internet searches for Diagrams; not all of these will be for your exact machine but all are similar. Cast about and you can see how your lever is supposed to work.
Bernina 740 diagram Google Search
Mar 29, 2015 | Bernina Sewing Machines
Bernina activa 230 sews a stitch then stops?
sounds like you bought someone else's problem, it could be mechanical or if the machine has a computer, that could be the problem, it would be a good idea to have the machine checked since it is used...
May 04, 2014 | Bernina Activa 130
Bernina 740 Replacement gear needed
check with these sites about parts
sewvacdoctor.com
a1sewingmachines.com
Oct 15, 2012 | Bernina Sewing Machines
Bernina 200 e freezing
Ask them to replace the I/O print and make sure its upgraded to the latest firmware, also have them check or replace the motor depending on when you bought your machine these could be under warranty.
Jun 18, 2009 | Bernina Artista 180
Sewing Machines Logo
1,193 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
