My kenmore laundry center will spin wont agitate
I have taken off the front panel and it is belt driven the machine will through the cycles but it will not agitate the motor wants to but will not and if you move the knob to spin it will spin and empty fine
jsrock516
  • 5911 Answers
SOURCE: agitated with my agitator and spin cycle
Your problem could be with your transmission, which is located directly above the drive belt pulley under the wash tub. If they go bad, your motor will still function normally, but the wash tub will not spin or agitate. Now, another possible problem could be a nail or screw stuck in one of the wash basket holes pressing against the outer tub. I have personally seen this a couple of times. A dry wall screw or nail will stop the wash tub from spinning and cause the drive belt to smoke as the motor pulley turns, but the belt stays stationary. That could be the source of your smell. If you're a do-it-yourselfer or do a lot of carpentry work, you may have washed some clothes with a nail or screw in them. Inspect all the holes in the wash basket throughly. A nail or screw can easily be missed if your not looking for it. I hope this may help you.
Posted on May 04, 2007
SOURCE: Washer won't agitate
Just fixed the same problem. Its a broken belt. Take the front panel off and to the right of the tub you will see a pulley and belt. We replaced both the pulley and the belt for around $40. Was real easy to do yourself.
Posted on Jun 06, 2007
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
  • 64 Answers
SOURCE: Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Posted on Sep 21, 2009
Washing machine will not spin at the rinse cycle
front loader belt driven ?
even a clutch system
if water is still in the bowl it wont spin
could be a water pump or water level issue
or timer or control board
Jul 04, 2016 | Kenmore Washing Machines
Washer does not spin but water goes out. Agitation does occur during wash cycle. Belt is in place and does move when pulled. When turning the agitator the tub moves. What would need replaced?
Motor will not turn the one way...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 19, 2010 | GE Spacemaker Washer and Dryer Electric...
My kenmore won't pump out the water. what could
couple of possible reasons and this will vary by brand of machine...lid switch could be bad...some machines will wash or agitate with lid up but will not spin unless lid is closed..others will not do nothing with lid up....some brands will not spin if the water level switch can detect water in the tub...this means your machine didnt pump the water out of the machine so it could spin couple of reasons for this 1 bad pump or bad pump motor(some machines have a pump that is driven by a drifferent motor than the one that drives the transmission)usually these machines use the water level switch to activate(turn on/off) the pump when the machine goes into spin cycle... some machines the pump wil come on and stay on for the entire spin cycle...some machines the belt will be bad and you just need a new belt....first thing to do is see if raising the lid will turn the machine off when it is in wash cycle if it does not..then it will in spin cycle..if the machine will not work in spin cycle the lid switch will be the reason why..
Sep 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
WONT AGITATE OR SPIN
check the belt that spins the tub, you will find it at the bottom of the machine, check if its intact.
plz do not forget to vote if i solved your problem
Sep 05, 2009 | Kenmore 24902 Top Load Washer
My front load kenmore 417-44072300 wont agitate or spin
you have a belt broken, drain out the water and take the back of machine off and you will find the belt then go to a place that sellls appliance parts andget a new one
Jul 18, 2009 | Kenmore 43042 Front Load Washer
Kenmore laundry center wont spin model number 417.90862990
* Test the lid switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
* Inspect the agitator
* Inspect the pump coupling
* Test the water level switch
For more information regarding this check out this link that describes more about washer troubleshooting...
http://acmehowto.com/howto/appliance/washer/diagwasher.php
Dec 12, 2008 | Washing Machines
Kenmore washer weak agitate even at fast load and no spin
It could need a new belt. If there is damage on the belt it may also be dirty or stretched and thereby slipping and not giving you it's best performance.
Aug 01, 2017 | Kenmore 43142 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
