Question about KitchenAid KAWS850L Top Load Washer
Whirlpool top load
When I put it on the wash cycle the water goes out and quick as it comes into the tub it will not fill up. There is no water on the floor
  • 640 Answers
Sphion effect...your hose is to low must come up height of machine before it can go down....or you have unit straight to your waste pipe...onthejob
Posted on Jan 31, 2009
Hey, I'm using whirlpool top load washing machine, the first whole procedure Went well initially, when the water was about to be drained off the machine, it turned off, later when i tried turning on...
PE error relates to the fill level of the washing machine. The fill level sensor is a pressure operated device. There is a sealed air line that goes from the bottom of the tub to an air pressure sensor. As the tub fills, it compresses the air in this air pressure sensor. When the tub is filled to the level selected on the dial, the sensor stops the fill cycle.
This air line can be plugged or the sensor itself can be faulty. This air pressure sensor is usually located near the top of the tub just under the top cover. If you can locate it, disconnect the air line from the pressure sensor and blow through it - it may be blocked by lint and soap from several washing cycles. There may be a filter in this line to help prevent this blockage. But the filter may have become blocked itself.
Dec 12, 2017 | Whirlpool Washing Machines
IN THE WASH CYCLE THE TUB FILLS ALMOST TO THE TOP THE DRAINS. THE OL CODE THE APPEARS AT THE END OF THE CYCLE
Hi, the OL code means Overloaded..
OL flashes when the machine/motor control detects a load size that exceeds the washer's capacity.Open the door lid to clear display, remove excess laundry, then restart the cycle.
Oct 04, 2010 | Whirlpool WTW6400SW Cabrio Washer
Water overflow when tub is emptying during spin cycle
It sounds more like you have a drain problem that a machine problem. Try draining into the laundry tub and check that the tub drains quickly enough. If not, you have a plumbing problem...Good luck...Nomess
May 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine won't stop filling up
PRESSURE SWITCH
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Apr 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirl pool washing machine tries to fill up but never fills up
This means it is stuck between the spin and rinse cycle and the time piece in the housing unit might need replaced if the knob itself isnt stripped also make sure it is on small or large load..
Dec 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Whirlpool LXR9245EQ2 top loading washer tub won't fill
try taking the knob off and see if the nut is tight on the timer,it might if came loose
Jun 18, 2009 | Whirlpool Washing Machines
Whirlpool LXR9245EQ2 tub won't fill at beginning of cycle
HI, you have a combination issue. the Water fill level pressure switch and, the cycle selector switch are both damaged and, they should be replaced. the total cost of these switches will run you about $90.00.
We recommend the hands of a skilled service tech when repairing this type of electrical issue.
Washer Fills/Drains at the same time
check that the drain hose saises above the water level of the tub. I f the hose does not come above the water level, the water will just drain right out
Dec 01, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washer will not fill with water
Is your drain hose lower than the top of the cabinet?? The curved part of the drain hose needs to be slightly higher than the top of the cabinet. Also, the drain hose must have an air gap around it where it goes into the house drain. It sounds to me like your washer is syphoning water out through the drain hose as it is trying to fill. Hope this helps..............
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
KitchenAid KAWS850L Top Load Washer Logo
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
