Question about Sony KP-57WS500 57" Rear Projection Television
Sony KP-57ws500 57in rear projection
I ve seen this issue from other users. I have a red shadow on my screen and ive read that it is the convergence board, particularly the ic's. I have never soldered a circuit board, so im not sure i am comfortable doing this, even though i think i could. Is it easier to replace both boards, and if so where can i purchase them? And some instructions on doing so. Thanks Al
  • Unknown Giansanti Jun 10, 2007
    Ok I undestand its more costly to do the boards, do you have the part numbers? I would like to see how much the boards cost, maybe in the long run it will be less stress on me if i just replace them.
    Thanks
    Al
    New Friend:
  • 129 Answers
Yes, you can do that but , boards are expensive ,its better to replace the ic's and may other resistors assosiate with to them. step by step folowing intructions may you can try only if you already have some tools. like soldering iron ,multimeter ,solder, and patience . hope this help you to make your decision, if you need part # let me know
Posted on Jun 10, 2007
  • Luis Amado Jun 12, 2007
    you can get the board from ptscorp.com 1-800-844-7871 they have refurbished boards /and or can rebuilt yours they are the only ones who can have it for around 345 dls plus shipping it has a core value of 75 dls when you return the old one to them.
    let me know
Sony rear projection kp-577hw40, screen turns red after being on for 10 minutes
This model and some others had bad picture tubes that are no longer available---there is an option here.
If screen gets bright red, green, or blue set will shut down as it detects too much current being drawn.
Seen over 100 with this issue--what can be tried and usually will help is a physical adjustment inside the set.
No parts to replace and takes about 15 minutes to do.
I can tell you how if you want to know.
Jun 13, 2012 | Sony KP-57HW40 57" Rear Projection...
Shadow
The sony convergence Kit Type 1 available at the following link will usually repair that issue. The kit contains the parts plus a CD with detailed instructions to do the repair.
www.tvrepairkits.net
Jun 25, 2009 | Sony KP-46WT500 46" Rear Projection...
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
Ghost shadows on the Sony KP-46WT500TV
you can get the KP46WT510 convergence repair kit at the following link under convergence repair kits category which will also work for your model.
http://servicemanuals.vstore.ca/
Apr 12, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony KP-61HS10 st start up blurry gets better the longer its on
You have loose solder connections on the convergence amps.This is a common problem caused by heat within the unit.If you can solder you can fix it.
Jan 12, 2009 | Sony KP-61HS10 61" Rear Projection...
Red color halo/shadowing
can you post a pic of your screen to show the shadowing, as red usually isnt affected with coolant contamination it may be a convergence issue. A pic would help me be better able to help diagnose the problem.
May 02, 2008 | Sony KP-53HS30 53" Rear Projection...
Convergence problem
did you try to do convergence thru the menu system?
Feb 21, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-61HS10 Rear projection TV blurry /shadows at first start
Sounds like the convergence ic's need to be replaced or resoldered. Sometimes it can be a microfuse if you are lucky. But my question is if you hit the focus button up front does it make it thru the auto convergence? Let me know. Have a good one.
Feb 09, 2008 | Sony KP-61HS10 61" Rear Projection...
Red Shadow
UNDER THE FRONT DOOR PRESS THE BOTTOM BUTTON "FLASH FOCUS" AND SEE IF IT FIXES IT. IF NOT AND YOU SEEN RED DOUBLE OF THE IMAGE, THEN THE SET PROBABLY NEEDS THE CONVERGENCE CIRCUIT REPAIRED.
DON.
Feb 01, 2008 | Sony KP-51WS510 51" Rear Projection...
Red shadowing...
first the conv. ic's need replacement then adj.
Oct 19, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
