Question about Sterling Plumbing 1500D-36S "VISTA PIVOT" SHOWER DOOR
Installation 1500d - Sterling Plumbing 1500D-36S "VISTA PIVOT" SHOWER DOOR
  • 653 Answers
You can download the installation instructions at http://www.sterlingplumbing.com/onlinecatalog/pdf/1063213_2.pdf Good luck and please don't forget to rate this.
Posted on Mar 15, 2009
  • Fahr Quad Apr 08, 2009
    So how did that work out???
Memphis 1500d amp
The flashing indicates that the amplifier is in 'protect' mode, which is often a sign of a ground fault, but may also indicate that one or more of your power and/or signal wires is crossed, connected incorrectly, or shorting out for some other reason.
In short: Go through all your wiring and check it thoroughly. Be patient, take your time, and I can almost guarantee you'll find the problem in a loose wire or perhaps your ground wire isn't connected to a part of the chassis that is fully grounded.
Unfortunately the Memphis 1500D is a discontinued model, so installation instructions for it are not readily available... however, the SPL 1500D is a very similar product and the wiring should be identical, so for your reference here is the installation manual for that unit:
http://www.spldynamics.fi/products/amplifiers/ICE-series/splclassDmanual1220.pdf
Hope that helps, good luck!
Dec 03, 2013 | Car Audio & Video
I have a Sterling 1500D Shower door and I need to replace hollow gasket at the bottom of the door. Where do I purchase this from???
It sounds like you need the sweep or seal that keeps water in the enclosure. You can buy these items, which are inexpensive and usually easy to install yourself at www.technologylk.com Technology LK carries a comprehensive range of shower door gaskets, seals and other hardware. If you have any questions about exactly what you need and how to install it, you can contact the company at www.info@technology.com or call them at 888-663-9830.
Jul 10, 2012 | Sterling Plumbing 1500D-31S VISTA PIVOT...
I have a Sterling 1500D shower door, the door has rubbed against the hollow bottom seal and ruined it- I can re adjust the door, I need the part number for the hollow seal kit.
I have the same problem. I'm doing research today, I'll keep you posted. unless you already figured out where to get the seal, please let me know.
Nov 20, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Have a sterling 1500D-42S shower door. Need to
sterling is an inexpensive kohler product,....go to a plumbing supply store with your #s and they'll be able to get what you need.
Jan 02, 2010 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Need instructions
Sterling has a video on their website that explained what I needed.
Aug 15, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Have Kodak 1500d. Import with photoshop turns off computer.
I have library of photos with HP. How do I import them to Kodak. It just comes up with Snapfish.
Apr 14, 2009 | Kodak Digital Science 1500D Path-Through...
Looking to purchase the Kodak Digital Science 1500D service manual
You can either buy it from kodak Kodak Customer Support: (800) 235-6325
or you can go to this site as well KODAK
and register
pls dont forget to rate solution
May 02, 2008 | Kodak Digital Science 1500D Path-Through...
Sterling Plumbing 1500D-36S "VISTA PIVOT" SHOWER DOOR Logo
446 people viewed this question
Top Sterling Plumbing Home Experts
john h
Mike
Rabbit Brains
Rabbit Brains
Are you a Sterling Plumbing Home Expert? Answer questions, earn points and help others
