Question about Whirlpool WFW94HEX Washer
Whirlpool WFW94HEX front load washer makes noise only during final spin cycle. When you spin empty tub manually, you can hear something slide around under tub. How do I get it out of there? There is n
It sounds like a coin or coins sliding around. There is no front kick panel. Front of washer is all one piece.
Coldcut
  • 1554 Answers
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Posted on Mar 04, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Posted on Dec 21, 2008
SOURCE: During the final spin cycle, our front loading
If the washer is brand new, look on the back panel and make sure the 4 transportation bolts have been removed. The bolts should be roemoved completely - they are only necessary to protect the washer during transportation.
If the bolts are removed, adjust the front two legs to be 1/4 inch higher than the back two. That 1/4 inch will balance the washer during the spin cycle, perfectly.
Posted on Apr 27, 2009
  • 77 Answers
SOURCE: It sounds like my whirlpool cabrio topload washer
Take the back off and run it take a flashlight and look inside for something that might have come loose.Hope this helps have a great Thanksgiving.
Posted on Nov 25, 2009
Testimonial: "Thanks for the help I'll check it out"
  • 353 Answers
SOURCE: Whirlpool Duet GHW9150P Front Load Washer is
BEARINGS
Posted on Dec 15, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Rattling noise in spin, spin problems becoming more pronounced. control panel lights flash but 0 error codes. unplug 2 reset, probl repeats
If this noise is happening while it's trying to drain water then you have something floating around in the lump. Coins are very common. If the noise is happening during a spin cycle and more pronounced during the final high spin cycle, you have bearing or spin tub issues. Time to go shopping.
Nov 07, 2013 | Frigidaire ATF6000ES Front Load Washer
My 6 year old Frigidaire front load washer makes a lound banging noise during final spin. I have read a bunch of stuff on the net about it being really expensive to fix. I never noticed that the drum...
A typical failure with your machine is that the rear tub seal may seep water into the bearings. Once moisture enters the bearings, they will quickly fail and cause the type of symptoms you mention. I would suggest purchasing a new machine as the repair cost can't be justified. Whirlpool / Maytag machines are very good and, at least relating to top loading, they are all made in USA. If you want a front loading machine made in USA, I would highly recommend the WFW94HEX model- Consumer Reports #1 rated.
Good luck.
Mar 27, 2011 | Frigidaire ATF6000ES Front Load Washer
We have a Whirlpool Duet WFW9400SW02 that is making loud noise during the high speed spin cycles. It is only 13 mos old. Whirlpool will not even stand behind the parts. The repair person estimates over...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Front Loading Washer is making a funny noise
open top cover (two or three screws on rear and slide back) and look at rear of tub checking clearance to rear panel and nothing touching belt or pulley. whirlpools tend to have a high pitch low volume whine anytime motor operates.
you really dont want to replace that bearing. part of tub assm. $400 part plus labor
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool WFW94HEX Washer Logo
77 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
