Question about Jandy Series Cl460 Filter Cartridge, 115 Sq. Ft
How to stop leaks - Jandy Series Cl460 Filter Cartridge, 115 Sq. Ft
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Clean seal coat seal with filter lube then put together tighten all the way so the copper nuts touch
Posted on Oct 09, 2014
How do i fix front seal leak? is there stop leak for that?
You can get stop leak products at your nearest auto parts store. Ask them for suggestions about the best one for your vehicle.
Feb 25, 2015 | Volvo 240 Cars & Trucks
Coolant leak barina xc
Water pumps do this.
Mar 21, 2014 | 1992 Holden Barina
Waterpump leaking
Not good! If your sure it not a hose leaking, you could buy some raidiator stop leak product at the auto parts store. The stop leak product will stop up your heater core so you won't have much heat in the winter, but it will probably stop your water pump leak if it's not a big one. I'd say replace the water pump and stay warm, unless you're not going to keep the vehicle much longer.
Jan 27, 2011 | 1991 Audi 100
Hi can anybody tell me what kind of stop leak would i by for a leaking freeze plug thanks
To be totally honest it usually isn't a good idea to use stop leak when you have a frost plug leak. The best solution is to have it replaced. If this is not an option, I recommend Bar's stop leak, it has worked very well for me in the past.
Nov 15, 2010 | 1993 Chevrolet Astro
2005 dodge caravan, leaking power steering fluid(rack n pinion), i am using lucas power steering stop leak. How long can i go with(lucas) before i replace the rack? fluid is not leaking anymore...
I really wouldn't push it more than 3 months or especially if climate change once the leak stop has stopped the leak it doesn't like temp change. but i've done radiator stop leak from Lucas and went 6 months before the leak appeared again. good luck
Jan 22, 2010 | 2005 Dodge Caravan
I put stop leak in radiator and now the car blows cold air vs hot air when running the heater. why?
The stop leak have restricted the coolant flow to your heater core. You can try flushing out the Stop leak with Preston Radiator flush or replace the heater core. Once Cooling system flushed out, replace thermostat, radiator cap and repair coolant leak. Good luck and hope this helps, and Note: Common Black kitchen Pepper does great as a radiator stop leak without leaving any residue and can be cleaned out of the system with water and not coolant flush. Two table spoon is more then enough to stop a small leak. Good luck and keep me posted friend.
Jan 11, 2010 | 2000 Buick LeSabre
Plz help 1996 Volkswagen Jetta
stp makes a p/w steering fluid with stop leak but this usually only works if leak is minor.you can try this for a few bucks and if leak doesnt stop then repairs are most likely needed. chris
May 09, 2009 | 1996 Volkswagen Jetta
Fuel leak
If you see the leak when you start the vehicle then you know where the leak originates from. You need to address the leak and find the solution to stop the leak. The leak does not go away. The extra heat just evaporates the fuel faster than it is leaking. This may make you think it stops when actually it has not.
Mar 12, 2009 | 1985 Ford LTD
Jandy Series Cl460 Filter Cartridge, 115 Sq. Ft Logo
57 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
