Question about Dryers
My hoover six express 1300 washer/dryer The belts slipping and today the drum was struggling to go all the way rould and i see a spark come from undernith machine is that cuz it needs a belt
  • vickihalstea
    vickihalstea Dec 08, 2012
    do u know if a belt from a hotpoint washing machine would fit my model please
    Sergeant:
  • 239 Answers
The felt glides have probably worn through at some point which will require removing the drum and replacing, preferably, the belt and all of the felt glides front and back.
Posted on Dec 08, 2012
  • vickihalstea
  • Strnj1
    Strnj1 Dec 08, 2012
    Ideally, the belt should be the part number for your specific model. Most are relatively cheap. The belt for my Maytag listed for eleven dollars and some change on one site.
SOURCE: MAYTAG DRYER LDE4914ACE BELT CHANGE
Dryer just stopped working, if you push the dial button in to start nothing happens at all. Dryer just stopped after runnig for about fifteen minutes.
Posted on Feb 14, 2008
TheMobilian
  • 8220 Answers
SOURCE: Amana dryer belt has come off, need to put back on, Help....
Here is a pictoral of a variety of different BELT CONFIGURATIONS for dryers
Posted on Mar 22, 2009
mikesagenius
  • 24 Answers
SOURCE: frigidaire FER211AS2 dryer drum belt
the washer has to be tipped forward. can access from bottom (and back).
Posted on Jun 03, 2009
hunter19_46m
  • 7482 Answers
SOURCE: can't find kenmore 80 series dryer drum belt
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Also for a manual I will include this website:
http://www.applianceaid.com/
Good luck,
I hope this helps
Posted on Nov 16, 2009
Testimonial: "many thanks... sounds like a lot of work unlike my old dryer"
  • 351 Answers
SOURCE: Bosch AXXIS dryer # WTA 3510 uc slipping /
drum baring or rollers if you can get belt off try to turn drum if it still hard to turn you will know its not the motor may be something in blower give it a try
Posted on Sep 30, 2010
Testimonial: "Will try it with help of a friend. Sounds much less expensive than replacing motor as Bosch dealer suggested. Thanks"
Our Hoover (3535d) dryer tumbler does not want to spin although you can hear the motor starting. The load does not appear to matter. There is no sign of belt slipping. Can the problem be due to the start...
If you hear the motor starting then it normally wouldn't be the start capacitor. It is when it doesn't start that you suspect the capacitor.
If your motor is turning and belt is NOT slipping then your drum should be turning! Those things do tell you that your electronic (control board and timer) are good, but you are wrong about either the motor or the belt!
Jul 03, 2011 | Hoover Dryers
Hoover Washer/Dryer WM120 : Dryer function - drum not turning
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
treru
Jan 25, 2009 | Hoover H120M Front Load Washer / Dryer
Hoover washer dryer saver 1300
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
Manual
Click on Hoover (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Oct 05, 2007 | Hoover H120M Front Load Washer / Dryer
Hoover six express wdm130 1300 washer dryer
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Aug 14, 2007 | Hoover AL130 Front Load Washer
Dryers Logo
112 people viewed this question
Top Dryers Experts
