Question about Sony CDP-CE375 5-Disc CD Changer
How to change fm channels - Sony CDP-CE375 5-Disc CD Changer
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
The Sony CDP-CE375 is a CD player, not a radio. It doesn't have any FM channels.
If you're asking about some other device, please specify the make and model.
Posted on Dec 08, 2012
How do i change channels on the FM source?
PRESS THE HELPFUL BUTTON
RE POST with the make and model # and question
Feb 04, 2016 | Televison & Video
Toyota-56037 radio (FM/AM) malfunctions..like... the system receives FM signals 76Mhz to 90 Mhz only although there are a lots of channels after 90Mhz. How to reprogram it? Plz help. TAUFIQ
if there is a mode button , press that and there is fm 1 whch is what you have , press again and you get fm 2 press again and you get fm 3
each fm number is a band width so select the band width that has most pf your stations and then auto select on it
if you have the owners hand book , the procedures are in ti for setting the radio
Nov 17, 2015 | Audio Players & Recorders
How do I change channels on my Maxon 49-sx
  • The "Maxon 49-SX" is a single channel transceiver that only operates on 49 MHz FM. The Maxon "49-FX" and "49-HX" operate on 5 adjustable adjustable frequencies. That radio has no channel/frequency options.
  • Hope this helps.
Nov 18, 2011 | Maxon 49-SX (1 Channel) 2-Way Radio
Don't know how to save and assign radio channels
ok change the channel to what u want to listen to then hold the number 1 button for like 3 sec or 5 secs then that channel is programed to channel 1 repeat steps for button 2 3 4 5 ect... with ur other fav stations u like to listen to.. then u can press the fm button to go to fm 2 which again u can program 1 through how ever many channel numbers ur radio shows now program different stations other then the ones u just programed on fm 1 choose 5 or 6 other station the fm2 just offers u more stations to program other wise just program the normal 5 or 6 stations to ur radio
May 16, 2011 | Car Audio & Video
FM channel set at 88.5, too noisy, need to change the channel to a quieter channel
Use the FM extender kit to improve the signal. You can change the channel by holding down the cassette icon to enter the menu, then going to FM options (I think it's under settings)
Jan 07, 2011 | Sirius Sportster 5 Satellite Radio...
How to play raido
hi,
u didn't mentioned the model number of ur Coy DVD, any way do the following
first of all connect the AM and FM antenna to ur dvd player. ( located in the back side)
take the remote and do the following
1 .press the AM/ FM button. make selection u need AM or FM ( if u want to turn channels on AM select AM and got next step, after that select FM and do the same for turning FM channels)
2. press the MO /ST button to select stereo.
3. press the AUTO button to auto tune channels available
4.what till all channels memorized
now ur radio is tuned. u can directly select the station using the numeric keys ( for eg:- to go to channel 2, u should press 0 and then 2, if u want o go to channel 14, press 1 and then 4.
u can also select channels by pressing the RADIO plus and minus button .
when u want to listen radio press AM/ FM button and select ur desired channel.
ok
Dec 17, 2010 | Coby 5.1 Channel DVD Player with Home...
FM Transmitter does not connect to car radio, have FX signal and Line out works.
Car cradle works "wirelessly" with Car Radio (inherent design of unit). Place Unit in Cradle; connect Cradle to Auto Power Source, and SkyFi3 should power on. Press Menu to Get FM Radio station channels; select a lower station Channel Frequency i.e. 88.3 or any vacant channel number and the signal should transfer to your Radio speakers automatically. You can change Station frequencies as often as you need to do so--for example if traveling through different broadcast areas, some channels frequencies are clearer than others. Good luck.
Jul 19, 2010 | Delphi SKYFi3 XM Radio Receiver
Only in certain areas and passing vehicals cause interferance
I'm assuming your using a RF unit (radio frequency). Whether this unit inserts in the antennea line or is simply broadcasting an FM signal via it's own antennea, it is still transmitting a low power FM signal. The idea here is to find an unused FM channel in your area, set your radio to that channel and program the Sony RF unit to use that channel. The signal the Sony RF unit is transmitting is low power due to FCC regulations and to minimize the possible interference you could cause to someone else's FM listening.
You are likely using an FM channel that is being overpowered by a real FM radio station. This is usually solveable if you only travel in your town by picking an empty FM channel. If you travel alot, the channel in your town that is empty may not be the case when you travel 50 miles away. That's just part of the problem inherent when using radio frequencies to get your music into your radio. You have to be willing to deal with it.
As far as passing vehicles, I'm going to assume that the vehicles that are interfering with your radio are doing the same thing you are doing, they are using FM radio frequencies to pump music into their radios and they are using an FM frequency close to or the same as the one you are using. Since having an unused channel on the FM band is pretty rare these days, if there is one, you can bet everyone is trying to use it for their own purposes since it is "quiet", until you come around!
Aug 07, 2009 | Sony CDX-454RF 10-Disc CD Changer
My midland allen 78+ uk channel has changed to am it should be fm
I Italy 40 Ch AM/FM 4 Watts I2 Italy 34 Ch AM/FM 4 Watts D Germany 80 Ch FM 4Watts/ 12 Ch Am 1 Watt D2 Germany 40 Ch FM 4 Watts/ 12 Ch AM 1 Watt D3 Germany 80 Ch FM 4 Watts/ 40 Ch AM 1 Watt EU Europe 40 Ch FM 4 Watts / 40 Ch AM 1Watt EC CEPT 40 Ch FM 4 Watts E Spain 40 Ch AM/FM 4 Watts F France 40 Ch FM 4 Watts / 40 Ch AM 1 Watt UKE UK 40 Ch Fm 4 Watts UK frequencies UKC UK 40 Ch Fm 4 Watts CEPT frequencies PL Poland 40 Ch FM/AM 4 Watts midland alan 78 multi plus frequencies
Jun 06, 2009 | Midland 1001Z 40-Channels Base CB Radio
Can i change my cb to fm
It would be fairly expensive & therefore impractical to do.
Jul 18, 2008 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Sony CDP-CE375 5-Disc CD Changer Logo
46 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
