Question about Homelite Garden
Ut10549 gas mix ratio
Gas mix ratio
  • 120 Answers
SOURCE: I have a Mac 3214 chain saw and I do not have the mix ratio
40 to 1 is the ratio
Posted on Jul 11, 2009
dontbother10
  • 2220 Answers
SOURCE: Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Posted on Sep 28, 2009
  • 4088 Answers
SOURCE: gas ratio
Most saws built within the last 30 years or so can be run with 40:1 using modern synthetic saw oils. A number of late model units run 50:1. Make sure to premix the fuel and oil before adding to the saw. Hope this helps!
Posted on May 04, 2010
  • 468 Answers
SOURCE: I need the gas mix oil ratio for the Poluan Pro 42...
40:1 gas to oil ratio.
Posted on May 28, 2010
J-Chris Ward
  • 731 Answers
SOURCE: What is the ratio mixer
I my self mix 40 to 1. Here is the manual look on page 9 at the bottom.
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2010/NOUS2010_115153026.pdf
Posted on Feb 12, 2011
Gas to oil mixture
Gas to oil ratio is a function of the oil you are using. Mix according to what the oil says not what the manufacturer of the engine says. Those ratios could/may be the same. IF you mix 16:1 oil (do they even sell that anymore ?) at a 50:1 ratio it will destroy the engine. There will be no problems at 16:1 as the oil recommends.
I have used 100:1 Optimoil (?) when I can find it instead of the recommended 48:1 of my 2cycle. No problems.
Mix the oil in ratio the oil manufacturer says to mix.
Sep 07, 2017 | Garden
What is mixing ratio for weedater
The ratio is generally 40 to 1. That is all I have ever used. It depends also though on the quality of the oil you use. Synthetics can use a different ratio than mineral oils.
Sep 19, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
How do I mix gas + oil for the husqvarna 128 ldx(what's the ratio)
It should be 50 to 1 it would be good to get a ratio rite cup an use it to measure your oil for gas . How ever the saw mix oil should tell you how much gas it makes
Sep 18, 2014 | Husqvarna Garden
On a gas chain saw, do you mix the gas
there is usually a fuel/oil ratio (i think yours is 50:1) you must buy the 2 cycle oil and mix it with gas at the ratio reccommended by the manufacture. the bottle may say 6 oz per 1 gallon = 50:1 So 1 bottle of 2 cycle oil for every gallon of gas. mix them in a proper fuel can. then let the cutting begin.
Mar 17, 2011 | Homelite ZR10926 16 Chain Saw
OIl gas mixture ratio?
one small bottle of oil from the auto parts store ( i don't know the oz. size)to one gallon to one gallon of gasoline; mixed well
Jul 23, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Gas/oil ratio for a Homlite yard broom UT 08026H blower
It's 40:1 but there are oil mixes out there now that you can buy that you mix with one gallon of gas and then it is safe for all 2-cycle engines...a real plus if you own multiple units with different mix ratios.
Jan 10, 2010 | Garden
Need to know oil to gas mix ratio for Craftsman 32cc, 360 cfm, 170 mph blower vac? Can someone provide ratio?
40:1 is the standard mix. Go buy one of the little containers ( 3.2 ounces) of 2-cycle oil and mix it with a gallon of gas in an approved container (like a gas can). How you mix it is, pour some gas in the container...about 1/4 of the gallon, then pour in the oil, mix well, by shaking the can then add the remaining gasoline and PRESTO, you have a 40:1 mix!
Nov 08, 2009 | Garden
Mcculloch 310 oil mix ratio
The proper gas/oil ratio is 50:1, that is 50 parts gas, to one part (2) cycle oil.
If you plan on leaving gas in the tank when not being used, I always recommend adding some gas stabilizer, such as Sta-bil, which makes starting the chain saw easier regardless of how long the fuel mix has been sitting in the tank or saw (up to 2 years according to Sta-bil label)
Hope you find this Very Helpful and best regards!
Sep 09, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
How to mix gas and oil ratio
hello. the mix has not changed over the years. it is important however to use ryobi oil. go to any home depot and get the small bottle of ryobi oil that is enough for just one gallon of gas, use new gas fresh from the pump, and enjoy.
Aug 18, 2009 | Ryobi Factory-Reconditioned ZRDS11008...
Garden Logo
29 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
