Question about Dryers
Hotpoint aquarius vtd20 tumble dryer button wont stay on
Hi, I have a hotpoint aquarius vtd20 tumble dryer (vented) when I press the button everything seems to work but the minute I let it go my dryer stops, I tryied replacing the button but still does this can anyone help? should there be a spring or is it a connection issue, any help would be great thanks x
  • 139 Answers
SOURCE: no heat
hi there
your problem is either the t-stats have blown which is very common or your heater is blown..
im guessin your t-stats beacuse they are the most common on hotpoint dryers to blow. There always blowing
They located at the back of the dryer behind the protuding panel so there for you dont need to open it all up just that panel.
To check if their blown check for continuity,, no continuity no good merry christmas cheers
Posted on Dec 24, 2007
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
barkencoa
  • 3463 Answers
SOURCE: my hotpoint vtd20 tumble dryer
If you can hear the motor running but no tumble action then belt has come off.
Make sure the door is shut properly..
If it gets hot at the back, then you are difinately getting power to everything.
If you can hear a slight buzzing noise, then the motor is failing to start, probably due to a faulty start capacitor.
Posted on Dec 08, 2008
barkencoa
  • 3463 Answers
SOURCE: I don't have any heat from my hotpoint aquarius ctd40G tumble dry
Remove the rear cover and you will see the element and stats, you will need a meter to test them.
Pull one wire off each thermostat and with a meter that beeps, test across each thermostat, if they are o/k, then the meter will beep,
if no beep then no good.
Replace all heater stats, even if only one has gone
If the stats are o/k then you will have to check the heater, this is more involved as it entails removing the top cover and left side panel looking at the dryer from the rear.
Unplug the heater lead, and again test with meter,if element o/k, then prob is timer or main pcb could be faulty, it really does get quite involved.
There is also a thermistor at the front of the dryer, that is part of the heating circuit.
Plz rate my solution.
Thnks.
Posted on Jan 07, 2009
barkencoa
  • 3463 Answers
SOURCE: Hi Can anyone tell me how to remove top from my
Undo screws at the rear of the top cover, and push and lift top at the same time.
Posted on Jan 02, 2010
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Hotpoint vtd00p thermostat
It could be the thermostat has burnt out or possibly the start capacitor
needs replacing
Aug 30, 2012 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
I have a vented TL61P Hotpoint Aquarius tumble dryer which will not heat with or without the no heat button pressed !Could this be a thermostat problem or the heater ?
check thermostats as above posts have commented check also condition of elements as my dryer elements are cracked and need replacing just had a new belt fitted so reluctant to let it go
Mar 19, 2011 | Dryers
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius vtd20 not heating
sounds like the heating element is bad or the heater box fuse and thermostat one of the 2 is bad,if you have a meter you can check all 3 on the ohms setting,let me know-mike
Feb 15, 2009 | Dryers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
fjj
Feb 15, 2009 | Maytag SDG4606A Gas Dryer
Hotpoint vtd20 dryer aquarius - cuts out when overheats
You can get spare parts on line by going to,
www.hotpoint.co.uk
Re your other prob ,it is probably due to a fault with the heater, disconnect the heater and run the dryer .if it does not cut out then your heater needs replacing.
Dec 10, 2008 | Hotpoint Aquarius WD640 Front Load...
My hotpoint vtd20 tumble dryer will not start. I was using it then when I put a second load in and pressed start - nothing happened. The power light is on but no tumbling!
Dec 08, 2008 | Dryers
Aquarius 1200 wd62 - Dryer not working
Most likely it is some sort of blockage in the vent, although it could be a bad blower. Check the lint filter and vent openings for a blockage.
Jul 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
91 people viewed this question
Top Dryers Experts
