Question about Garden
Starter not egaging right?
The starter gear is captured in fly wheel when not engaged. I do don't believe this is normal. Are there shims available to adjust the Starter? What has transpired with this engine is rather a long story. had starter serviced by a local altenator & starter shop. when reinstalled it is always turning with the engine."no power applied" engine is nor installed at this time.
  • Ted Mostert Dec 08, 2012
    This engine is not mounted. Thought I had a catistrophic problem pilled engine off and opened case to inspect. while turning shaft heard rubbing sound near starter removed starter still had noise, reformed flywheel shroud till noise went away. at that time had the starter serviced, when installed the drive gear of the starter turns with the flywheel i do not believe this is correct.
  • 2,239 Answers
There are two types of starter, a bendix gear type,and a pre engaged type, neither should rotate with the engine running, with a pre engaged starter the gear is connected to the flywheel but when the engine starts a solinoid pulls the gear out of the flywheel, with a bendix type, the starter motor spins the bendix shaft which in turn winds the gear up and into the flywheel ring gear.
Posted on Dec 08, 2012
4 Suggested Answers
SOURCE: john deere 425 lawn tractor. it wont start but it
My John Deere did the same thing. Turned out to be the emergency brake sensor.
Posted on Jan 21, 2010
  • 146 Answers
SOURCE: starter gear doesn't move up to engage flywheel gear when started
The solenoid does two things -- it closes an electrical contact to run the starter motor, and also pulls a lever to slide the motor gear up to engage the flywheel. Since the contact is closing, the solenoid itself must be OK, but the lever could be broken, or the sliding gear could be binding or stripped. Since you're looking at a probable replacement, try cleaning with compressed air, then squirting some WD-40 into the starter gear area - you could get lucky! Otherwise, you can replace the starter/solenoid assembly -- you can find replacements on eBay for about $80. Less expensive but more time consuming is to remove the assembly, disassemble, and replace just the defective parts if you can find them. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 15, 2010
SOURCE: The recoil starter on my Briggs & Stratton not engaging flywheel
Andy, Hi, well I would start at the Starter myself, usually the thing called the "Bendix" spring jams up and stops it dead. Pull of the Starter, and power it up, off the unit. This will show you if it snaps in and out.
Sometimes a few judicious whacks with a soft hammer will sometimes free up the spring, if thats is indeed what's wrong. Anyway try that first. before any disassembly.
Make sure the Motor CAN actually be turned, by turning the flywheel, this should show you if the Motor is "Free" enough to move.
Also check ALL electrical connection to the starter. Use a meter and see if you are actually getting a voltage to the starter too. make sure your starter battery is good too.
Below is your support site, for any manuals or parts required. http://www.briggsandstratton.com/maint_repair/
Posted on Jul 21, 2010
I have a 95 s10 that I just had a complete clutch job done on. Every since then, I've had trouble cranking it. The starter is engaging (its new) but its not turning the fly wheel. What could my problem...
1: Low battery voltage
2: mis-aligned starter requiring shims
3: mis-aligned starter that has to many shims
4: bad engine ground
5: incorrect ring gear, (may have been changed with flywheel during clutch job
6: damaged pilot bushing in crankshaft, or incorect bearing installed during clutchjob
7: the wrong clutch altogether, I've seen that happen before, it may be to large or wrong shape and touches the bell housing, make sure you can turn the engine by hand while someone else completely engages the clutch, if the vehicle tries to move while clutch engaged and you turn the engine, there is a problem that can only be remedied by removing the trans and finding it.
Jan 09, 2015 | 1995-1997 Chevy 1500 Truck Ignition...
2001 v6 auto tribute starter dos'nt engage ring gear consistantly
most common issue is the starter is aligned properly, this can be fixed by shiming the starter ( most replacement starters come with shims, if not you should be able to get them from your parts store)
the next most likely issue is worn drive gears on the starter or fly wheel
May 26, 2014 | Mazda Tribute Cars & Trucks
Starter issue?
check starter mounting bolts either loose or missing one. if starter old probably starter drive pinion or fly wheel worn out.if starter new.but smaller size than old one you need to use shim on starter.
May 28, 2013 | Cars & Trucks
I have replaced the starter 3 times and most of the time it sounds like the bendix isn't hitting the flywheel ring gear
You need to make sure that the starter is positioned right first, sometimes they need to be shimmed to change the position. In some cases though this can mean a warped a fly wheel. Make sure none of the teeth the fly wheel are missing. I had one missing once and anytime it hit that spot i had to move it which isnt easy on an automatic.
Jul 23, 2012 | 2004 Dodge Ram 3500 Truck
90 blazer, starter problems, grinding at flywheel, tried, new bolts, shims, and new starter, how often do you have to use 1/2 shims?
inspect fly wheel good could have bad ring gear. check torque convertor bolts they are tigth. with starter bolted up NO SHIMS push out pinion gear and check clearance at flywheel teeth . you can use a feeler gauge (ROUND DIAMETER) measure clearance between top of flywheel ring gear tooth & bottom tooth of pinion tooth on starter clearance should be 0.01-0.06inchs. can ge shim in different gauges. DONT USE MORE THAN 2 SHIMS. some times you have to shim them but not often most of the time if use shims have a flywheel issue.
Nov 23, 2010 | GMC Jimmy Cars & Trucks
So I go to start my truck and it will not turn over. . . I have had this problem on and off for years. If I was to roll the truck back and forth sometimes it would start. I have tried starting it in...
Mist likely you have a bad spot on the flywheel.
The Starter GEARS - engage with the FLYWHEEL GEARS and turn the engine until combustion takes over. You have a problem there. GM is well known for this.
Check the starter that it has the correct number of shims - GM uses shims to keep the starter the correct distance away from the flywheel. You might have to take it to a qualified GM mechanic. Not necessarily a factory shop but one who knows GM uses shims and why.
Apr 01, 2010 | 2003 Chevrolet Silverado 1500
Starter turning engaging not start
 you need a shim, if its screaming your clearance is to great. Are you positive its the right starter?
Feb 19, 2009 | 2003 Ford Ranger Regular Cab
Garden Logo
200 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
