Question about Watches
Why does the time stop after six to eight hours? Do I have to wind it often?
I'm guessing it's a Fully Automatic watch,which if worn all day should store enough 'kenetic energy'without manual winding!! You can buy watch winders on eBay that constantly move the watch when your not wearing it to keep it wound up!!
Posted on Sep 24, 2014
2 Suggested Answers
smitty5609
  • 243 Answers
SOURCE: Twenty year old Timex Automatic (self-winding).
If its a good watch, take it to a watchmaker. Dont know to find one 30 yrs ago they were inevery city
Posted on Oct 05, 2011
Watch stops after wearing for a few hours
Self winding watches need motion ( wrist twist) without they can stop. Sometimes just shake your wrist for a few seconds. I purchased a winder box for times I don't wear. ( Amazon)!
it is belt driven winder, rotates watch 5 minutes every hour.
Apr 21, 2015 | Rolex Submariner Oyster Watch for Men
Timex 1440 sport indiglo 50m convert from 24 hour clock to 12 hour clock.
There are several models of your watch not all of which appear to have a 12/24 hour display format.
Try this extract from a manual; press the MODE button six times to enter the 12/24 adjusting setting and then use the START/STOP or SPLIT/RESET button to change the time.
Press the mode button to return to normal operation.
Dec 06, 2010 | Watches
Omega constellation self winding watch stops
Omega claim that your watch will run for 40 or more hours, so stopping overnight should not happen. I doubt if you need to be particularly active to wind up the watch, otherwise this would make the problem quite common. My one experience of owning an automatic did not raise this sort of problem.
Discuss your problem with your supplier and describe your use. As you correctly say, having to hand wind i defeats the point of buying an autoamtic. (It could be that you have been sold two duff watches, however unlikely this may seem, it could happen).
Jun 06, 2010 | Omega Constellation 95 1262.15 Watch for...
Bulova Millenia 100 m,stops running,move it to wind,starts up
When you say "wave wind" do you mean you're waving it around to wind it with the self-winding mechanism? If so, that will only keep it running briefly as you're experiencing. Manually wind the crown about 40 turns clockwise to "fill the tank" and wearing it daily will keep it topped off. Anytime you don't wear it for a day, manually wind it again. As for the cleaning, the inside of the watch doesn't get real dirty but over time the lubricants wear out and thicken which makes the watch run slowly or not as long as it has to work harder to move the gears through the thickened lubricant. A watchmaker can disassemble and clean the old lube out with solvents and then reassemble the watch with fresh lubricants.
Apr 27, 2010 | Watches
My wifes recently repaired Rolex loses about an
Is it an automatic self wind or wind up? An automatic watch has a weight that winds the main spring and if you wind it by the crown it will not stop. If its one that you wind by hand then the watch should be wound daily at the same time...like right before bed or when she wakes up. Wind gently until it stops. That costly repair should come with a warranty so if she consistently winds daily and still loses time you need to send it back!
If the watch is an automatic then she can gently hold the watch in her hand and rock it back and forth a good 20 times or so and that will give it a good winding! This is a common issue we see at our watch repair business. Some people do not move enough during the day to keep an automatic movement wound. If thats the case then there is nothing ong with the repair, just make sure it gets a good daily wind! :-)
Jan 10, 2010 | Rolex Watches
Losing time stop after couple of hours
If this is genuine, it is Kinetic and needs to be wound for the first time as wrist movement sometimes isn't enough. Undo the pin that sets the time from its  initial position and then start turning the pin clockwise to wind it. If the time or date changes, you have pulled it out too far, push it back in as far as it goes without screwing it back in place then start winding it.  You will need to wind it about 50 times.
Hope this helps
Apr 25, 2009 | Breitling A1336313 Bentley Gt Racing Watch
Keeping 2008 breitling cockpit watch running
You have to wind the watch till it is fully wound (significant resistance should be felt).
It doesn't matter how many times you wind it (1 or even 40) - what matters is the strength of the spring.
Do as follows:
At any time in the morning wind the watch up till you feel there is no more winding left (should be quite tough). Memorize the time you did it.
Leave the watch (or wear it) till it stops completely.
Count the hours your watch did work (from the time you wound it).
Now you know exact power reserve for your watch.
It is advised to wind the watch 2-3 hours before the power reserve is gone.
Rate me.
, please.
Apr 08, 2009 | Breitling Navitimer A2332212 G5 431A watch
Problem winding a Invicta Skeloton Mechanical Stainless Watch
The Tag Heur repair center says an automatic watch must go through an "initiation" process. They recommend winding manually 40 revolution of the crown clockwise. You must wear an automatic watch at least eight hours per day. Repat the initiation if the watch is not worn for 20 hours or so.
Dec 12, 2008 | Invicta Watches
The watch stopped working
Apr 08, 2007 | Prague 49011-M1
Watches Logo
91 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
