Question about Brother SE400 Computerized Sewing and Embroidery Machine
Why won't the feed dogs lever on my brother SE400 machine move?
My machine that I have only had since August 2012 will not work properly. At one point the feed dogs dropped in the middle of my sewing and wouldn't come back up. Took it in for repair and now the material will not "feed" through and I am unable to move the lever to raise or lower the feed dogs. What might be the problem?
SOURCE: I have a Brother 98-Stitch
I dropped my feed dogs and when I pushed the button to bring them back up, it wouldn't work. I did discover that when you put the button back to the up position and start sewing, the dogs come back up automatically.
Posted on Sep 16, 2008
bargainbox
  • 1388 Answers
SOURCE: Brother Super Galaxie 2100 - Feed dogs will not lift
Remove needleplate and clean out the built up lint between the teeth of the feeddogs.
When moveng from Feed Down to Up, rotate handwheel one revolution to re-engage.
If neither is a problem and your manual is of no assistance, take it to a service centre to check it out and quote.
Posted on Aug 19, 2009
talk2ginny
  • 34 Answers
SOURCE: Feed dogs dropped on brother pq1500s, won't come back up
Welcome to FixYa! You can purchase a manual for the PQ1500 from this site:
https://www.sew4less.com/product/4255/Brother_PQ1500_Instruction_Manual
If you have a minute, please rate my answer honestly so I know whether I understood your question and provided helpful information. Thanks so much, and good luck. Feel free to comment if you have other questions, or if you'd like me to search for other links.
Posted on Feb 05, 2009
  • 3 Answers
SOURCE: Brother XL-6562 sewing machine is not feeding fabric through properly
Oil might help but it sounds like you don't have enough pressure on the foot. You can take the casing off where the light is and there is a screw back there that controls the tension on the pressure foot. It is not meant to be changed by anyone but a professional. I've changed the tension but it wasn't easy. If you are still interested let me know and I will try to explain.
Posted on May 21, 2009
  • 152 Answers
SOURCE: my feed dogs will not come up into position
Some machines have to take a stitch for the mechanism to "pop" back into place, I don't really know if your brother is like that but try to sew with it and see if they click back into place.
Posted on Oct 23, 2009
Why can't I get the feed dogs to come back up?
the slide switch could be broken, also could be a problem with the feed dogs, machine needs to be checked
Feb 14, 2016 | Brother SE400 Computerized Embroidery and...
Fabric won't move threw machine, feed dogs are working.
Try adjusting the pressure on the presser foot, or make sure your feed dog are in up position and moving forward
Jan 06, 2013 | Sewing Machines
Brother XL 5130. I just got this machine and the feed dogs seem to be in the 'down' position, although I can't find a lever anywhere to move them up. In some of the forum, it suggests that
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Look up "darning" and it shows a feed dog cover so that means this machine does not have dropping feed dogs.
Now that that is out of the way... most machines have the ability to adjust the height of the feed dogs. But without seeing your machine I can't advise you. It might be better to go have the machine adjusted and serviced.
Dec 11, 2012 | Sewing Machines
My fabric dosnt move foward or back wards with the petal or manually ..
if the fabric won't move then there is something wrong with the
feed dogs, check in the needle plate to see if you can see the feed
dogs. you should be able to see them & touch them with your finger
since they are not moving the fabric it would be a good idea to
have the machine checked
I'm putting a link for a free manual for the machine, you can check
in the manual to see if it show where the feed dog lever is on the
machine, if it doesn't show a lever, or the lever is not responding to
movement then the machine needs to be checked to see what's
wrong.
http://www.singerco.com/uploads/download/463_2932_esf.pdf
Sep 04, 2012 | Singer 2932 Mechanical Sewing Machine
My brother cs6000 won't sew buttonholes
change the needle
some machines have a button hole lever that must be pulled down
before the button hole is started
but it's also possible that the machine needs to be check to see if
there is something is wrong with a part inside
check the feed dog to make sure it's in the up position
if you don't have a manual here is links that you can choose the right one
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000_ES_2000_EN_185.PDF
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000B_EN_2888.pdf
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000i_EN_2889.pdf
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000T_EN_2890.pdf
Sep 04, 2012 | Brother CS-6000
Does XL5340 have drop feed dog lever?
Look on the back of the machine for a slide-type switch near the sewing area.
Aug 22, 2012 | Brother XL-5340 Mechanical Sewing Machine
My SE400 keep bending or breaking needles while trying to embroidery.
Machine breaks needles
1.make sure you are using the right needle for your type of sewing machine.
Most machines can use generic Schmetz needles. There are cases where the machine will only use ones specified in the owners manual.
2.the presser foot may not be installed properly
3.use the correct needle for the type of fabric you are working with. To fine of needle on heavy fabric or to course a needle on silk or jersey can damage fabric.
4.let the feed dogs guide the fabric & the feed dogs will work with the presser foot .
5.the needle is not all the way in -push all the way up against the stop
Mar 14, 2012 | Brother SE400 Computerized Sewing Machine
Feed dogs not moving properly
it's very possible that the feed dogs are out of time & the machine would have to be serviced at a sewing machine repair shop
Mar 05, 2012 | Kenmore Sewing Machines
I cleaned my machine, but after putting the plate back on, the feed dogs don't pull the fabric through now.
check the feed dogs to see if their up, you can see & feel them with your finger under the needle plate.
if the feed dogs are not up then somewhere in the cleaning the knob or lever got moved, go back thru what you did to find the feed dog knob,,it's always good to know where it at
Sep 07, 2011 | Brother CS6000i Computerized Sewing...
Brother SE400 Computerized Sewing and Embroidery Machine Logo
866 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
