Question about Sewing Machines
Correct threading of mitsubishi db130g sewing machine
  • Sewing Machines Master
  • 1,564 Answers
AtlasLevy.com call or email them for instructions on how to do this. I thought there might be a video on Youtube didn't find one. However, he does say anyone can call or write for threading on any machine.
Good luck
Posted on Dec 10, 2012
  • 8 Answers
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
Posted on May 20, 2008
  • 12 Answers
SOURCE: thread constantly wraps around spool pin
Cut a round curcle of fabric the size of the spool from a piece of felt. Put a hole in the middle and put it under the spool of thread. If this does not work you can purchase a small net that fits over the spool. It is designed to keep the thread from coming off the spool except for being pulled through naturally.
Hope this works.
Zelma
Posted on Jan 19, 2008
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
Michaelle
  • 65 Answers
SOURCE: need help to thread our sewing machine.
you really must get a manual for this machine.
You can find manuals online for a small price.
At one time some sites had them for free, but I haven't been able to find many recently. sewusa.com has some older ones for free. but not many. you could try the kenmore site as well, if not I'd try to search on dogpile.com (sewing machine manuals)
Just so you know, your manual is the MOST important tool for any sewing machine, and its worth a couple of bucks to get it.
Posted on Jan 24, 2009
  • 323 Answers
SOURCE: conse sewing machine...broke needle...put new
machine threads left to right and the hole is on the side. the long groove of the needle goes to the left.
needle must be 135x17
sewman7
Posted on Mar 20, 2009
Why does my machine break the thread a lot? A juki cp 130
tension too tight or incorrect threading, or bad thread.
Mar 13, 2017 | Juki Sewing Machines
Can't pick up bobbin thread when I do manage to get the bobbin thread through . the machine works away making the holes but not sewing Singer 7462
Unfortunatlly if it will not pick up thread, it is possibly out of time. But before you go changing the timing, make certain it is threaded correctly, the bobbin is threaded correctly. If they are all good see my tip on time a sewing machine.
Jul 19, 2010 | Singer 7462 Mechanical Sewing Machine
My brother sewing machine won't pick up the thread from the bobbin
If it is the correct needle length, and the needle is in correctly and threaded correctly, then the machine is out of time.
May 19, 2010 | Sewing Machines
My prdect is fashionaire 2380.when i'm sew somthing it's break the thread,and it's stack
Check the thread spool to see if there is a nick where the thread is catching. If there is, you can smooth away the nick with an emery board, or just flip the spool so the thread is feeding from the bottom of the spool.
Sometimes the thread feeds too quickly from the spool and puddles around the spool pin. A thread net (can be purchased online or at a sewing machine dealer) can eliminate this.
Check the threading to be sure it is correct - always thread to top thread with the presser foot up.
Check the bobbin to be sure the thread is feeding from the bobbin spool in the correct direction and through the correct guides.
Refer to your manual for threading and bobbin position.
Feb 20, 2010 | White Sewing Fashionaire Sewing 2380...
MITSUBISHI DB 130G threading instructions
I am looking for a manual for the Mitsubishi relsew DB-130. I need to know the best way to thread the bobin and the correct way to put in the needle. I will take a photocopy of the manual if someone has one?
Aug 02, 2009 | Sewing Machines
How do i adjust mitsubishi industrial single needle sewing machine dy337
What needs to be adjusted? First of all make sure you have it threaded correctly. There are a lot more holes and threading points than an household sewing machine. If it is the tension that needs adjustment you will see the tension dial just above the needle slightly to the left. It's the grey knob. Turn it clockwise to tighten the tension. Turn it counter clockwise to loosen it. Thread with two different colors of thread, one color in the bobbin, another color for the spool. Sew a line of stitching...if you see the top spool thread pulling to the underside then you will need to tighten the tension. If the bobbin thread is pulling to the top side then you will need to loosen the tension. If you want to adjust the stitch length then turn the dial that has numbers on it. #2 is pretty small stitches, I use #3 for most sewing and #4 and 5 for topstitching or basting. Good Luck! Hopes this helps.
Jul 31, 2009 | Sewing Machines
Bobbin thread not feeding into the upper needle thread
completely unthread the machine....ensure the needle piston shaft is in the correct position and retread the upper. reinstall the bobbin and turn the machine by hand to engage the bobbin thread. Draw the bobbin thread through the stitch plate and with the needle thread, allow to trail off the back. attempt to sew a piece of scap material.
please let me know what happens at this point.
clarkco
Feb 08, 2009 | White Sewing Fashionaire Sewing 2380...
Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Jul 29, 2008 | Singer Inspiration 4210 Mechanical Sewing...
Brother 3022 Mechanical Problem
Make sure your needle is in correctly. Check your threading again. If that does not work, remove throat plate, install new needle, turn hand wheel until needle is at its lowest position and observe if the hook is exactly behind the eye of the needle. If that is correct then you do not have threaded correctly. If it is not then the machine needs to be re-timed.
Oct 09, 2007 | White Sewing 2037 Mechanical Sewing...
Sewing Machines Logo
213 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
