My dstv dsd 1131 when switched on doesn't show
SOURCE: My decoder - dsd 1131
Don't worry about it. You have mistakenly pressed Shift + exit. What you need to do is to press Shift + i. What you have done is used by the people using two decoder. They use it to switch between the two decoders.
Posted on Dec 30, 2010
SOURCE: no signal from dstv decoder
no signal for dstv for my decorder pls help me.
Posted on Mar 20, 2011
  • 102 Answers
SOURCE: We are installing our new Toshiba flat screen TV.
Make sure you are on the correct input on the TV, I.e select Scart if you are using a scart lead and HDMI if your using a HDMI lead. If you have confirmed this to be corrct then you may have a defective cable or worse case senario a faulty port on the tv depending on the cable you are using.
Posted on Mar 24, 2011
bugoy31
  • 1238 Answers
SOURCE: my tv showing an amber light instead of red standby light and now it won't switch on
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Jun 21, 2012
spr1949
  • 1182 Answers
SOURCE: TV screen screen's blank but it's on stand by. whenever using a remote it does not show anything.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.If problem persists, please refer it to a qualified service technician.
Posted on Jul 25, 2012
What can be the problem if my Dstv decoder model DSD 1131 doesn't have signal strengh or signal quality I'm staying in Pretoria how can I fix the problem
The best that I can give you is at this link:
http://hopeafrica.tv/index.php/component/content/article/40-schedules/202-dstv .
It should be noted that Africa does not have digital tv so you should probably hook an antenna to the tv without the box and have the tv search for analog tv stations as that will stand the best chance of picking up what few channels they do have.
Good Luck!
Rich Lilja
Jun 12, 2015 | Televison & Video
How do I setup 2 tv,s on a single view dsd 1131 decoder, 1 tv and decoder upstairs an 1 tv downstairs. The dish is already installed and can rust very easily for the area.
very simple ,, the tv next to the decoder must be conected using a rca cable and then run normal tv cable (RF out ) to the other room
Apr 04, 2013 | Televison & Video
Is it possible to unlock dstv channels by entering the codes?
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 27, 2012 | Cell Phones
Jul 25, 2012 | Televison & Video
Have a Sony Bravia KDF-50E2010 rear projection tv. Will not switch on, blank screen, flashing red light. What is wrong and will it be expensive to rectify. thanks.
Unfortunately from the description it sounds like the bulb has died. The red light is the customary indicator of a dead bulb. Usually you will get a warning from the TV but that is only a timer based warning and doesn't reflect the actual bulb life.
These are not cheap bulbs but you can find some excellent deals on-line if you search the model number of your TV in your search engine. I would caution you against anything that is "remanufactured" or "rebuilt" as these have questionable reliability and generally a shorter life span which will negate the cost savings.
May 23, 2011 | Televison & Video
Dstv decoder dsd 1131 is just flicking when put on power.cause of problem is that water dropped on mother-board.there was carbon but i brushed it with methylated spirit.but is still flicking and does not...
In most cases if there was water and the set was put on before the traces were removed , it is quite possible that some sensitive component could be damaged.
hence it is important to start from the beginning. Use a hair dryer to warm, use soldering iron to solder suspected joints and if you hear/see steam while the iron is used on the pins then it is for sure that water is lodged in the component base. You will need to do the work with caution till there are no traces. A slight short can result in flickering , if not there are failures in the board.
check this link for some tips;
http://www.fixya.com/support/r6041626-when_device_falls_into_water_when
Apr 12, 2011 | Televison & Video
My decoder - dsd 1131 does not respond to his remote control.Ive checked the batteries..they are ok.
Nov 28, 2010 | Televison & Video
Free to Air on a Dstv
how can i have codes to tune east african channels plis for free. am using dsd 1131 decoder of dstv. am in johannesburg.
Jun 18, 2010 | Televison & Video
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
Electro Med Services...
