Question about Water Dispensing & Filtration
I have an in line water filter (#38447) going to our refrig that I purchased in 2008. I ordered one on 11/28/12 (order # 435285004). I received #4638447000 filter which has quick connect ends with O-rings. I need one with 1/8 or 1/4 female pipe threads. Can you tell me the correct part number ?
  • 26 Answers
SOURCE: Reattach Power LED, Power SW, and HDD LED leads
go to the manafacturer website, there should be plans for the motherboard somewhere on there
Posted on Nov 24, 2008
alicantecoli
  • 22326 Answers
SOURCE: 1965 triumph herald car, wiring to fuse box
1342 firing order ,listen its been 40 years since i had one of these cars ,cant be difficult they only had 6 fuses of the glass type ,just need to get ign switch feeds right ,doesnt matter about amperages just use 25 amp in them all it wont hurt
Posted on Feb 02, 2009
  • 147 Answers
SOURCE: correct order of panel 1 connections
which kind of hardware you have?
can you provide with brand name and model please, in order to help you?
Posted on Apr 10, 2009
  • 17 Answers
SOURCE: My bathtub drain is American Standard circa 1927.
your close to figuring it out,
I would guess you have a hair clog in the trap. they have inexpensive plastic rods (like a long zip tie) with serrated edges on it to capture the hair. Home Depot or Lowe's or Menards will have these
Posted on Jul 05, 2009
  • 7353 Answers
SOURCE: I have a Ferret 40 Charging system analyzer and I
http://www.ferretinstruments.com/CategorySelect/BatteryTesters.html
Posted on Mar 13, 2010
How do I clear the line from the water filter to the water dispenser and ice maker on my Frigidaire Refrig # FGHF2344MFO?
That's a great question, Steve!
I see that you would like to clear the line from your water filter to your dispenser and icemaker on your Frigidaire refrigerator. In order to do so you would need to disassemble your refrigerator. This is not a simple DIY job and I would recommend having a professional technician out to perform a proper diagnosis and repair. This will prevent any personal injury or future issues. -Matt
May 19, 2015 | Frigidaire Refrigerators
Tip
GE / Hotpoint S xS Refrig: Will not dispense water
Remove lower grill and disconnect the water line going through the freezer door hinge. Usually it is a push lock fitting, which requires you to push the ring on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
on May 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a 2008 bottom freezer refrigerator 795.7854 with water on left side of refrig door and water is not flowing. Changed filter and checked water supply and they are ok. What else can I do?
There is usually a solenoid where the supply water hooks up. Need to check it. Pull off hose going from solenoid to freezer and see if water comes out of solenoid when water is pushed on door. If it comes out there, then the line may be frozen.
Mar 01, 2014 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Water in door not working. I haven't changed the filter in a long time...
Is the ice maker working ? If so , the filter is not the problem . At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Nov 13, 2009 | GE Refrigerators
Replaced water filter, water stopped working at all after 3 weeks
Remove lower grill and disconnect the water line going through the freezer door hinge. Usually it is a push lock fitting, which requires you to push the ring on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X101073 water tube heater. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
Comment by MNTECH, posted on May 20, 2009 Sorry, didn't notice that I put an extra zero in the part number. It should be a WR49X10173
Aug 28, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Water dispenser works sometimes
It sounds like you may need to try the water tube heater I mention in the "Tips and Tricks" post of mine, copied here:
May 07, 2009 | GE GSH25JFR Side by Side Refrigerator
Water filters
Go to www.whirlpool.com/accessories or call 1 800 901 2042 and have your model no. They should be able to help you either way!
Aug 14, 2008 | Whirlpool GS6NBEXR Side by Side...
Jenn Air JRSD209T
This is just anecdotal here, but one repair guy who came out and thawed a frozen line into the icemaker told us the fridge required near-full line pressure 90- or 70- or whatever that is, in order for the ice maker to work. This was a licensed repair guy. We were feeding it with an RO, which only pumped it in at 17 or 20 psi (or whatever the unit is) which he informed us was inadequate. However, after he thawed things out and we changed out the inline carbon filter in the fridge, everything was hunky dory for a couple of years. About a year back, the icemaking stopped, and changing out the carbon filters in the fridge AND in the RO system did the trick.
Now we have a different problem. Things aren't getting or staying cold, especially the fridge. I opened the housing in the back of the fridge, defrosted the extensive ice accumulated around the refridgerant coils, and everything ran great for a couple of days. Now we're back in the global warming pattern: steadily rising temperatures and thawing. I'm not feeling too happy about Jenn-Air these days.
Jun 17, 2008 | Jenn-Air JCD2389G Side by Side...
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Water Dispensing & Filtration Logo
293 people viewed this question
Top Water Dispensing & Filtration Experts
ray gallant
Tom Chichester
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Are you a Water Dispensing and Filtration Expert? Answer questions, earn points and help others
