Question about Lexmark X6650 4-In-One Wireless InkJet Printer
My computer doesn't recognize my printer
I even bought a new printer cord and tried several different usb ports but it still doesn't recognize my printer. I downloaded lexmark software but during the installation it asked to connect the printer to the pc and obviously I cant do that, it doesn't let me continue on to the next step either.
  • Official Brand Answer
  • 3,344 Answers
It's possible that the problem is with the USB port on the printer. If you have a router, you can try to connect your printer using an ethernet cable so you won't have to configure your printer using a USB cable.
Once you have connected the printer using an ethernet cable, proceed with the installation in your computer and choose ethernet as the connection type. It should automatically find the printer on your network.
Posted on Dec 10, 2012
SOURCE: installing Lexmark 1200 series
Cannot install original Lexmark All in One disk on new computer. Windows Vista Home Premium.
Posted on Jul 25, 2008
SOURCE: lexmark 2500
i need a lexmark 2500 imaging studio...can anyone help me?
Posted on Aug 03, 2008
SOURCE: I have a Lexmark Z738
drivers.myfreewares.com/driverdeveloper-287-lexmark-download.html - 26k - download the driver from there i had the same problem when trying to download it for lexmark site or try puting lexmark z738 driver xp in goggle
Posted on Oct 14, 2008
mamun97
  • 29 Answers
SOURCE: Lexmark Printer Install - No Communication Error
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
866
Posted on Mar 02, 2009
SOURCE: Lexmark X8350 "communication not available"
I fixed this by completely uninstalling the Lexmark software, then unplugging the USB and restarting. I then installed the new Lexmark software that I downloaded from their site, make sure not to plug the USB back in until it told me to. It then detected the printer properly and started working.
Posted on Jun 03, 2009
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Usb device not recognised lexmark s405, tried all advice listed in google pages except petrol & lighter.
Have you tried using another USB cable? You can also try plugging the printer in to a different USB port in your computer.
Also, try to plug in the printer to a different computer, if it works then there's a problem with the USB port of your computer. If it still doesn't recognize the printer, it could be the USB cable that's causing the problem or the USB port of your printer. If that's the case and your printer is still under warranty, contact our technical support team to have the printer replaced. You can find the contact number at our site: www.lexmark.com.
Jul 05, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Computer won't recognize USB port HP Photosmart 7960
when you plug in the printer and turn it on do you get the sound that a USB device as been added
NO :
try a different cable
YES :
it might be worth trying new drivers only ad downloading the latest version direct from the manufacturer
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ps-18223-2&cc=uk&dlc=en&lc=en&os=228&product=305383&sw_lang=
Hope this helps
Dec 14, 2011 | HP PhotoSmart 7960 InkJet Printer
My Lexmark z2300 sends to the printer & it says it's printing, but it doesn't actually print. I've tried several file types & programs to print from but none of them work.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Sep 14, 2011 | Lexmark Z2300 InkJet Printer
My computer doesn't recognize my dane-elec 8gb usb stick , although other usb devices do work.
1. Try a different USB port. If other ports recognize it, then the original port is fried. 2. Try a different computer. If the other computer does not recognize it, then your flash drive is damaged.
Good Luck!
Aug 19, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Computer will not recognize mp3 player, device doesn't light up
The two most likely causes for this is either your USB port or the USB cable itself. Try plugging the device into different ports and if that doesn't work, get yourself a different USB cable. If neither of those works then your device is faulty and the only fix for that is to get it serviced by the manufacturer.
Jul 02, 2011 | Computers & Internet
MY COMPUTER SAID IT DOES NOT RECOGNIZE MY USB CORD
It will never say it doesn't recognize a USB cord.
A USB cord is just that--a piece of wire. It might tell you that it can't find the printer.
Has the printer worked before?
If you are installing it for the first time, did you install the software before plugging in the printer?
If you have done all these things, then either the USB port is bad or the printer is.
But--try uninstalling the printer first--and any software that came with it. Then reinstall the software and plug in the printer.
While I did mention that the cord is just a piece of wire, it is possible that the cord has become damaged in some way. Try using a different cord. Also, try using a different USB port.
Apr 18, 2009 | HP LaserJet P2015dn Printer
Computer won't recognize USB ports
If you are plugging a USB device into a different port it takes some time to recognize and install it - it re-installs for every port. There could be cable and/or port issues as well. Plug the printer into a USB port that the mouse does work on and allow several minutes for it to detect install it.
Dec 18, 2008 | Dell Dimension E521 PC Desktop
Hp officejet 5610 all in one printer
you can use the serial/usb adaptor to connect it to your computer
May 07, 2008 | HP Officejet 5610 All-In-One InkJet...
Laptop doesn't recognize my printer
unusual not to be recognised, assuming you have followed the instructions word for word, eg not connected the printer until told to etc, you may have a problem with the usb port and not the printer, so to illiminate this try installing in a different usb port. Also try this driver from the Samsung web site http://www.samsung.com/Products/PrinterandMultifunction/BlackWhiteLaserPrintersforHomeandHomeOffice/ML_2010XAA.asp If still no luck then it's either the printer or a usb port problem, to illiminate the usb fault, go to my computer, right click>properties>hardware tab>device manager> and go down the bottom of the list to usb controllers, click on '+' sign, right click and select uninstall. Restart pc and all the usb controllers will be re installed automatically. Try the printer again, if still not installing the fault must be the printer.
May 06, 2007 | Toshiba Satelite A10 Notebook
Lexmark X6650 4-In-One Wireless InkJet Printer Logo
73 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
