Question about Breville BKC600XL Coffee Maker
Chemical taste in breville coffee maker ,how do I get rid of it?
6ylucy
  • 742 Answers
SOURCE: where can i purchase manual for brevillefilter coffee model cm 1
Get Breville manuals here.
Send them your model # and they will get it.
Posted on Feb 13, 2010
  • 60 Answers
SOURCE: dose Breville make a 220v modle of this coffee
Unfortunatly not
Posted on Mar 23, 2010
cmccune04
  • 213 Answers
SOURCE: Lost the K-Cup holder and cannot find where to buy the part
http://iwantsweetdeals.com/Keurig-B30-B40-B50-B60-B66-B70-B77-Replacement-K-cup-Holder-Assembly-Part-J-P1208231.aspx
This part fits your brewer too!
Posted on May 26, 2010
mcdevito75
  • 1970 Answers
SOURCE: My Breville Keurig coffee maker turns itself off
mcdevito75 here, It may need to be cleaned, if the brewing holes are clogged it"ll signal coffeee maker to shut off. Refer to owner manual for cleaning.
Posted on Jun 22, 2010
  • 58 Answers
SOURCE: My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Posted on Jun 24, 2010
What do I do to make the taste of my coffee less intense/bitter?
This might sound like a joke, but I'm serious. Use less coffee. Grind size only has limited effect. When you buy different beans, you may find you need to use more or less coffee depending on the type of bean itself. In fact, I'd bet buying different brands is what is confusing you regarding how _much_ to use.
Mar 10, 2015 | Breville Coffee Makers & Espresso Machines
How can I make the coffee not so strong tasting when using the Breville Oracle?
Adjust water (more) and bean quantities (less), see here: http://brevilleusasupport.com/bes980xl/care-and-use/menu-functions/
My breville bes870xl filter light won't stop flashing single and double. I've unplugged the unit and plugged it back in and turned it on and it still continues to do this.
PDF]Getting to know your machine - Breville
https://www.brevilleusa.com/media/.../BES860XL.pdf
Translate this page
rested coffee beans produce espresso with much more taste .... filter size you select, and along with the GRIND. AMOUNT dial ...... create steam. When the steam lightstops flashing it is ready .... cappuccino machines is purchased. THE RIGHT ...
Dec 07, 2013 | Breville Coffee Makers & Espresso Machines
The ice from my ice maker has a chemical taste...how do I get rid of it?
Run about 3 cycles of vinegar; then rinse with water. Run regular water through and then the ice should lose the chemical smell and taste.
Mar 30, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
Lost instruction manual. How do I clean coffee maker to get rid of strong acid taste coffee? MoldelB60 single cup coffee maker
Most coffee pots are cleaned by running 1 part white vinegar and 1 part water. Just put in the reservoir and run a cycle. Once completed, run again with 1/2 pot of water only and it will clean it. If you use your pot daily, this should be done once every few months. If you have foul tasting coffee, you should use bottled water to rectify that. Plain tap water has minerals that dilute the taste of the coffee and over time build a residue in your pot.
Oct 09, 2010 | Keurig B60 Coffee Maker
Coffe taste like water. It's not strong enough, but I do everything like I'm suppose to.
You're using either stale coffee or the grind and tamp on the coffee is not correct.
Mar 07, 2010 | Breville ESP8XL Espresso Machine
Coffee tastes waterdown
for grounds you need to tamp the ground hard,. Fill the port a filter to the top then tamp it until the little line is showing. Also what may be a problem is the grind is too fine, or too course
Feb 12, 2010 | Coffee Makers & Espresso Machines
Strong metal taste, how do I get rid of it. Coffee tastes terrible with very strong metal taste. I have boiled kettle about 8 times, but am unable to get rid of bad taste.
Professional chefs face this problem many times over with their stainless steel wares. Fill the coffee pot with water. Add a tbs of bleach. Let set for 2 hours. See if that helps. If it doesn't, please let me know.
Oct 20, 2009 | Breville SK500XL Stainless Steel Cordless...
Kitchenaid 14-Cup has plastic, chemical taste
Run 1/4 cup vingar with a pot of water. The coffee is not finishing its cycle and some remains in the works. You may have to do this several times. Washing the carafe with ice and salt by swirling it around a few times until it sparkels clean. Last thing for a good cup of coffee is filtered water which will keep the unit cleaner too. :)
Sep 18, 2009 | KitchenAid KCM400 Coffee Maker
Coffee tastes like metal
THIS HAS NOTHING TO DO WITH THE COFFEE. This has to do with water filter system and most importantly descaling of machine, as over time the metals in side machine and tubing get a mold type build up. Its a chemical reaction from the water and tubing and the coffee and metals. To 100% solve this, descale the machine with water and vinegar mixed. Do this a couple of times and use bottled water to fill water tank if you do not have a good water filter tap system. I have been the espresso business for over 16 years with 4 locations, and it has nothing to do with the coffee. If it was the coffee or poor coffee it would tasted burned or bitter, but NOT tasting like metal.
Please rate my solution as you see helpful, Thanks Mike Espresso Expert
Jul 02, 2008 | Dacor CM24P-1 Coffee Maker
Breville BKC600XL Coffee Maker Logo
81 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Delierious
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
