Question about Hotpoint Washing Machines
My washing machine has stopped filling up with water
The machine was in the middle of doin a wash and water (not a lot) started coming out the front and then just stopped.
ginko
  • 19396 Answers
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    • 29 Answers
    SOURCE: frigidaire front washer has power but won't fill up, drain or go through correct cycles
    You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
    Posted on Oct 15, 2008
    • 958 Answers
    SOURCE: fill will not stop
    you may have a problem with your pressure switch. or sometimes they call it the water level switch.
    try to use it in the small level and see if it would stop filling around medium or large quantities of water.
    if it would stop filling , then replace the water level sensor.
    tnx 4 using fixya,
    drcool
    Posted on Oct 19, 2008
    buzzwood
    • 65 Answers
    SOURCE: INGLIS WASHING MACHINE - WATER STOP
    Either call the store where you purchased the machine or refer to your users manual, should have a trouble shooting guide in the back of the manual.
    Posted on Jan 05, 2009
    • 240 Answers
    SOURCE: Kenmore 70 Series washing Machine won't stop filling with water
    filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
    Posted on Apr 28, 2009
    I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
    If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
    Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
    Water does not come into machinetub -front load stacker
    If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
    Washing Machine Problems No Water
    Washing Machine Fix Washing Machine No Water
    heatman101
    Apr 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
    Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
    My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
    Jan 04, 2010 | GE WSXH208A Front Load Washer
    Washer stop in middle of rinse cycle
    All content © 2000 © 2009 Washerhelp
    > Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
    Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
    Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    In the middle of a cycle, it has stopped and is
    nf is NO fill
    i would check your cold water line
    take it off the machine and check the screen as well
    no fill means it is timming out waiting for water
    Oct 09, 2009 | Samsung WF337AA Front Load Washer
    Front loading ge washing machine only 2 months old. door locks,
    take water lines off of water valve at rear of unit and clean dirt out of screens.
    Jun 19, 2009 | GE WSXH208A Front Load Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Doesnot stop filling water
    To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
    To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
    Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
    Mah2400aww
    The problem is the washer is defective.
    Jan 18, 2018 | Maytag MAH6500 Neptune Front Loading...
    Washing Machines Logo
    104 people viewed this question
    Top Hotpoint Washing Machines Experts
    vince
    Todd Arndt
    Todd Arndt
    puggy666
    Level 1 Expert
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
