Question about Cameras
Power button works but will not wash clothes
Need help washer has power but will not register that you are pressing start button
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
You posted this question in the digital camera area of FixYa. Please repost your question in the appropriate area, and specify the make and model of the device you're asking about.
Posted on Dec 08, 2012
How to calibrate samsung top load washing machine
there should be another 7 letters/numbers after wa14 maybe the full model number is on the back or in a manual
Sep 19, 2015 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
Mar 18, 2015 | Whirlpool Washing Machines
Le keep coming on
dfgf
dSorry to read about your problem, I hope this helps you out.Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG Washing Machines
The drum is not spinning and the machine stops and has LE on display
3 Thumbs - Helpful
3 Thumbs - Helpful
Jan 01, 2011 | LG Washing Machines
What is a le code and how do i fix it thanks cathy
sdfsf
sdfSorry to read about your problem, I hope this helps you out.Is this a new installation?
3 Thumbs - Helpful
3 Thumbs - Helpful
Error code LE
In new installations, this error can sometimes present because of a mis communication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
3 Thumbs - Helpful
3 Thumbs - Helpful
Dec 27, 2010 | LG WM1814CW Front Load Washer
Error code F1 on Kenmore Elite "Oasis" clothes washer
Instructions Press "Stop" to clear the current cycle on the washer.
  1. 2
    Press the "Power" button to turn off the washer. Unplug the washer from the power supply.
  2. 3
    Wait several minutes. Plug the Oasis washer back into the power supply and press the "Power" button to turn on the washer.
  3. 4
    Select the desired wash cycle and press "Start."
Dec 12, 2010 | Washing Machines
How do i put intuitive eco on to just spin clothes not a whole wash cycle
press power button press up button 2 times on option button to "wash advance" press adjust button to which ever rinse cycle youd like to use. press start.
Jun 05, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
I press the start button and it says error.
Had the same symptoms. Tried unplugging power for 5 minutes, no change. Did the Select+options button for 5 seconds, the column of lights flashed once, and then I hit the Start, the door locked, clean clothes followed shortly thereafter :)
Jun 12, 2006 | Frigidaire GLTF2940ES Front Load Washer
Cameras Logo
11 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
