Question about Uniden DECT 2080-5 Quint Phone
I need a manual for DECT 6.0 Uniden phone
Does not ring in and would like to fix it
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
You may download a copy of the manual here.
Posted on Dec 08, 2012
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
  • 569 Answers
SOURCE: I need an Uniden phone DECT2080 owner's manual.
You can find the manual here:
http://www.uniden.com/pdf/DECT2080om.pdf
Posted on Dec 16, 2009
consultel1
  • 860 Answers
SOURCE: my cordless phone says
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Posted on Dec 21, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: UNIDEN DECT 6.0
DECT 6.0 is not a model number, it's the generic name for the cordless phone technology in use. So I can't give you a more specific link than this one, which takes you to Uniden's download page for manuals. Pick your model from the list, and the manual will explain the steps you'll need to follow. Your phone's model number is on a sticker normally found on the rear or bottom of the base unit.
Posted on Mar 27, 2010
Testimonial: "thank you very mucy "
HOW DO YOU RESET ANSWERING MACHINE ON 6.0 UNIDEN PHONE
Answering Machine - Uniden Support
unidensupport.com/AnsweringMachine
Get support for your Uniden Answering Machine. ... For models that have an */envelope key on the handset: ... How To Change The Record Time & Ring Time.
Customer Support
mycusthelp.net/UNIDEN/_cs/AnswerDetail.aspx?sSessionID=&aid=270585 How Do I Set The Greeting On My DECT 6.0 Cordless Phone Answering System? Question: Answer: To record your greeting on the DECT Single-Line Models, please do the following: 1. ... features your model may have can also be found in your owner's manual. ... http://www.uniden.com/index/manuals_results.cfm?cat=1
I have a Uniden phone/answering machine, DECT 6.0, number ...
www.justanswer.com > Electronics Question > Phone Problems I have a Uniden phone/answering machine, DECT 6.0, number BK20033715. I purchased it about a year ago. I need to change the message on the answering ...
[PDF]owner's manual - Uniden Australia
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/DSS7955_1_OM.pdf Terminology used in this Manual . ... Answering Machine Features . ..... change global settings at a time, and you have to make sure the phone is not currently ...
Owner's Manuals - Uniden
https://www.uniden.com/product-information/owners-manuals Owner's Manual. Search for an Owner's Manual. The product name/model number is on the product's ID label on the back, bottom or in the battery compartment ..
RESET ANSWERING MACHINE ON 6 0 UNIDEN PHONE Google Search
Apr 20, 2017 | Uniden Lands Phones
How do I make the ring tone louder
Press the up-arrow while in stand-by mode, as described on page 4 of the manual.
If you need a manual, you may download a copy at Owners Manual User Guide for Uniden D1780 Dect 6 0 Cordless Phone With...
Oct 17, 2016 | Uniden D1780 Dect 6.0 Cordless Phone With...
Uniden user guide
Select the model of your Uniden DECT 6.0 system from the list beginning at http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Aug 23, 2014 | Uniden DECT 6.0 Cordless Phone ID
Manual for uniden detect 6 phone
Since you neglected to specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Aug 28, 2012 | Uniden DECT 6.0 Cordless Phone ID
Change the rings from 2 to 6
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Jul 04, 2012 | Uniden DECT 6.0 Cordless Telephone...
Uniden dect 6.0 _cordless phone. is stuck on silent mode ,lost the manuel need to know how to get it off ..phones wont ring
Select the model of your Uniden DECT 6.0 phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
Sep 21, 2011 | Uniden DECT 6.0 Cordless Phone
How can I get it to ring 7 times before going to voicemail?
Since you didn't specify the model of your Uniden DECT 6.0 system, select it from the list beginnng at
to download the manual.
You may have to settle for 6 or 8 instead of 7.
Aug 10, 2011 | Uniden DECT 6.0 Cordless Phone ID
I have lost the manual and want to know how to get the answering machine to pick up on 6 rings and not the 2 that it came programmed with from the factory?
Select the model of your phone from the list beginning at
to get the manual.
Jun 30, 2011 | Uniden DECT 6.0 Cordless Phone ID
Answering machine picks up after 3 rings .
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Jun 20, 2010 | Uniden DECT 6.0 Cordless Phone ID
Uniden DECT 2080-5 Quint Phone Logo
71 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
