Question about Jandy AQUALINK RS TELELINK KIT
Replace 6474-G board
Lightning may have fried my Jandy Power Board
    Top Expert:
  • Jandy Master
  • 6,465 Answers
Need more info what doesn't work
Posted on Jan 30, 2016
3 Suggested Answers
  • 6 Answers
SOURCE: jandy lite2 heater has fl5 error code, all voltages look good
If all voltage test points are within range, then it's 1 of 3 problems: Power Conversion Plug is faulty; Power Control Board is faulty; or Controller is faulty. Jandy says there is no way to test any of these directly. They recommend that you replace both the Power Conversion Plug (~$35) and the Power Control Board (~$230). Apparently when one fails, it can cause the other to fail as well. They said that unless the Controller has a lot of corrosion on it, then it probably is not the issue.
Posted on May 20, 2010
  • 368 Answers
SOURCE: My inside controller says the pool pump is off but
Yes, it could be the board but if the system has an external relay this relay's contacts could be welded and therefore causing the motor to run. If you have a meter and are very careful you may be able to measure the voltage on the wires coming from the controller to the relay and if there is voltage being supplied to the relay coil then it is the board's fault, if not then the relay is bad. I hope this helps.
Posted on Aug 22, 2011
TV no power.Cable hit by lightning.
if didnt have a surge protector and unit took a lightning hit more than likely unit totally fried
Jul 31, 2016 | Televison & Video
House struck by lighting,all cable boxes and two tvs fried. already replaced power supply.
Nobody can predict what might have been happened to electronic equipment; during a lightning. In most cases, main board to these devices might get damaged. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 05, 2015 | Samsung Televison & Video
After lightning storm whole system died. Still 12v supply from battery and 18v AC to board but all lights and panels dead. Any advice welcome.
What AC voltage should you have to the board . If it is mains power then something has been fried.
Dec 25, 2014 | AC Cars & Trucks
My inside controller says the pool pump is off but the pump keeps running, the only way to turn it off is with the breaker. It has a 6474-G board. could the problem be on the board?
Aug 21, 2011 | Jandy AQUALINK RS TELELINK KIT
LG47LH30 lightning took out several appliances. TV won't turn on or any lights at all - acts as if it is not plugged in. Should I even try to fix? Are there interior fuses?
The lightning has fried at least the power source of the tv. Even if you you replace the source there are big chances that other components/boards have been also damaged.
There is nothing you can do to it, take it to a repair shop to have it diagnosed professionally.
Jul 03, 2011 | LG 47LH3000 LCD TV
I have the same problem with my Jandy PCB 6473 E board aassembly 6475 as posted, can anybody fix this board?
I can repair most jandy issues except when the board has a fried processor. Ussually cost $100 plus shipping for repair.
wmcgreevy@comcast.net
Dec 14, 2010 | Heating & Cooling
After lightning struck in my backyard, printer won't turn on.
HI, this was an unfortunate surge that has fried the power board Assembly in this unit. it has also fried the main control. this may be a total loss unless, you are considering replacing the entire mother board and power assembly as well.
Replacing the main control board and power board will restore proper function.
May 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
Jandy one touch control screen
your RS board in the power center is shot. that message means there is no communication to the power center.
Sep 13, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy AQUALINK RS TELELINK KIT  Logo
47 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
