Question about Lenovo 3000 Y410 Laptop
Lenovo reboots My Lenovo (Y410) attempts to boot windows, but it reports an error and then continuely restarts. I could start it in safe mode, so I was able to back up data, but now it will not work in safe mode either. Appreicate any help/advise!
  • stushap Jan 12, 2009
    I was afraid it would come to that - I assume I'll lose the data on both the c & d drives. Thanks - will try it tonight.
    Yeah, 95% - the system would crash even in safe mode, but then there is all the reinstallation of software (Office, Norton, Spysweeper, Wireless LAN software, Card Reader, etc...)& then al the updates. It will probably take me a couple of days to get it back.
    Again THANKS for the help and advise!
  • 31 Answers
Do you have the restore disk? I recommend formatting and completely reinstalling windows. This should help you. If you need further instructions, feel free to ask.
Posted on Jan 12, 2009
  • crogers2009
    crogers2009 Jan 12, 2009
    I hate to say it, but yes, you will loose all the data. I thought you backed it up though in safe mode?
  • crogers2009
    You're very welcome. I do understand the frustration. I just had to re-format my work computer about a week or two ago,and it's STILL not back to normal.
How to run 3000 y410 laptop in safe mode
Hit F8 during the boot process to bring up special boot features like Safe Mode. With Windows 8 you can open a search bar and type "Startup". Select Change Advanced Startup Settings". Select Safe Mode. Reboot.
Oct 04, 2013 | Lenovo 3000 Y410 Laptop
Windows Error Reporting Error
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. Hope this helps.
Dec 30, 2012 | Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Lenovo Y410, It does not boot. Throws error: There was problem in staring windows due to some error. How do I get to start windows in safe mode?
Welcome to FixYa
It seems that you are having problems booting to windows. There are a number of steps you can try to fix this issue.
1. boot to safe mode. Start tapping F8 right after the computer turns on. This would cause the system to boot to windows advanced boot menu. Once you see the advanced boot menu then just choose safe mode. If you managed to boot to safe mode then you can perform system restore from here. To run system restore just click on start, all programs, system tools, then click on system restore, once system restore has been launced choose a date when the computer was working fine
2. You can also try to boot to windows recovery environment. to do this keep tapping F8 right after the computer turns on. choose the option "repair my computer". The system would now boot to windows recovery environment. From here you can run startup repair and system restore
3. If none of the above steps work then you can use the One Key Recovery feature of a lenovo Y410. Please note that this would reset your computer to its factory image so this would cause you to LOSE DATA on the system. Before you use this feature make sure that you have a back up of all of you data. Note that the computer must be turned off. Press the NOVO button on the computer. refer to the image for its location on your computer
Pressing this button while the computer is off would launch the one key recovery of lenovo. From here you can restore the system to its factory condition.
Hope this helps
May 22, 2011 | Computers & Internet
Recently my laptop, lenovo 3000 N100, has a power shortage
if there is a option saying boot in safe mode wtih out networsk try that
also press F8 you will see some extra options try that tooo that will work i did it in a virus affected system
i think the sole reson is some boot files are missing. if the above ones dont work try reinstalling
Jun 17, 2009 | E-Machines eMachines Desktop PC
Computer will not boot up. I have tried to boot up in safe mode, normal, safe mode with prompt command...nothing works, just goes back to the normal start up screen and keeps doing the normal start up over...
It looks like you're encountering an endless reboot? Here's what to do to find the actual error message.
  1. Turn on the computer, and press F8 after the POST screen but before Windows attempts to start to access the advanced startup options.
  2. Select "Disable Automatic Restart On System Failure" and press Enter.
You should now get a blue screen with an error message and error codes. Please write these codes down and report back.
Mar 24, 2009 | HP Compaq Presario SR1830NX PC Desktop
At start up my computer reboots 2 or 3 times
Hi there!
Try running on safe mode. Here's how you do that power on your PC press F5 continuously untill you see the boot menu and select safe mode. from there run the following: antivirus, checkdisk and spyware removal. hope it helps.
Mar 18, 2009 | Medion M3 Director 5100 PC Desktop
Vistas explorer restarting
try booting into safe mode by turning on the laptop and keep on pressing F8. It should bring you into a menu. Choose safe mode. If you can get into safe mode then click on the windows icon in the bottom right hand corner and then in the search box, type in MSCONFIG. Click on msconfig when it pulls it up and when you go into that program then choose the startup tab and disable all.
This will stop all of your programs from starting up when you go into windows. Reboot the computer from this point and see what happens after you get back into windows. If this solves the problem then that means a program starting up is the problem.
Feb 22, 2009 | Lenovo 3000 Y410 Laptop
Will not start up
if at all, the case is tat, it just starts ur computer and gets hanged at a stage where, ur motherboard company name is displayed, then,
click del button, and there, in settings, u enable quick boot and restart, and it will work..
pls, let me know , i f it works
Jul 17, 2008 | Computers & Internet
Lenovo 3000 Y410 Laptop Logo
106 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
