Question about Sony Alpha DSLR-A100 Digital Camera
CANNOT FULLY INSERT MEDIA CARD INTO MY SONY a100 camera. media card will only go in about 1/4".
SGNath
  • 170 Answers
SOURCE: I have a sony a100. It says unable to use card
What card do you use on the A100? And what capacity? Are you sure you have inserted it in the correct way? Be careful while inserting a CF card because of you insert it wrongly, it can damage the camera. Zooming is done using the zoom ring on the lens barrel. Just twist the zoom ring. Hope you are using the 18-70mm kit lens with the camera.
Posted on Feb 10, 2009
robmcd27
  • 423 Answers
SOURCE: I have a sony dslr a100 and when I hook up the
Was your camera off when you connected it to the pc? It has to be off in order to work. Also, Does your camera require drivers? You might have to have the driver installed in your pc order to work.
Also, did you plug in your camera to your pc and go to my computer to see if it's listed there as a drive?
Rob
Posted on Mar 05, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony A100:put in empty CF cards, says card full, won't format
Might be 2GB card is more then enough for camera hardware o handle. Try 1GB card in this camera.
Posted on Mar 15, 2009
miket756
  • 2702 Answers
SOURCE: pin missing in card slot of Sony A100, I get the
well it cant read the card,,, its a shop job to fit a new card reader slot bord,, pricy job too,,,sorry
Posted on Oct 30, 2009
toheed99
  • 33 Answers
SOURCE: Sony Alpha DSLR-A100 Digital Camera
Its a minor problem. You can check form website the address of nearest service station.
Posted on Mar 16, 2010
Testimonial: "thanks, I was worried"
Bought a sony dsc h300 camera about 2 years ago...bought a Kingston Memory card for it....what do I do now ?
Have you tried formatting the new memory card? Sony suggest you format a new card using the camera.
Supported capacity:
  • Memory Stick Duo" media: up to 64 GB
  • "Memory Stick Micro" media: up to 16 GB
  • SD card: up to 64 GB
  • microSD memory card: up to 64 GB
You may also want to check the camera's user guide to narrow down what's causing the card not being detected.
http://docs.esupport.sony.com/dvimag/2014/DSCH300_guide/en/contents/12/01/04/04.html
Jul 08, 2017 | Sony Cameras
Sony Cyber Shot DSC-H9
The camera may display a MEMORY STICK ERROR or C:13:xx message (xx can be any random number) on the LCD screen for the following reasons:
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Remove and re-insert the Memory Stick® media several times.
  2. The inserted Memory Stick media is not compatible with the camera. Check your instruction manual for information regarding Memory Stick media compatibility.
  3. The inserted Memory Stick media is not formatted. Format the Memory Stick media using the FORMAT option in the camera menu. WARNING: There is a risk of data loss. Formatting will erase all stored data, images, movies, etc., from the Memory Stick media.
  4. The terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
  5. The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
Thanks
Proton
Oct 02, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Will NOT turn on when sd media card is inserted
look through the SD slot, all pins should in position and clean, if something looks wrong, try to clean or adjust the pin with philips #000 screw drive or similar size tools
if everything looks just fine, try to put another SD card.
if nothing works to you, through it to trash or sell on ebay.
Jan 28, 2014 | Kodak EasyShare M380 Digital Camera
How to fix "reinsert memory
Welcome to FixYa.
There 3 possible causes why do you received an error message " reinsert memory card"
Cause
1 The inserted Memory Stick media is not supported for use with the camera.
2 The terminals on the Memory Stick media are dirty.
3 The Memory Stick media is damaged
Resolution
1 Ensure you are using the supported type and capacity of Memory Stick media for use with the camera
2 Use a clean pencil eraser and lightly rub the Memory Stick terminals to remove any oxidation or dirt build-up
3 Use different Memory Stick media
I hope this steps wil help you to resolve your isuues.
Thank you for using FixYa.
Apr 04, 2011 | Sony Cybershot DSCW310 Digital Camera
Hi the camera cannot read the memory card, i have chaqnge the card and still can not read it.
The Sony has an interesting array of memory media of which one of them (I don't know which you are using) is possible to lock (write protect) but this requires a pin or some other sharp pointed instrument. If the card is new then this is a possibility if you have been using the card then it's not likely the problem.
Diagram
With the memory card checked to make sure the protect switch is in the "read/write" position then I would say your memory card needs to be formatted to the camera. This is found in the camera's menu here is a diagram
Diagram
This should solve your problem.
Jan 20, 2011 | Sony Alpha DSLR-A100 Digital Camera
Powers on, lens extends, 3 beeps, lens closes, camera turns off
Try doing a couple of things.
1) remove and digital media cards.
2) turn the camera on and delete any pictures that may be stored in the camera memory (not on a removeable card)
3) remove the batteries for 60 seconds
4) replace the batteries without the media card and lay the camera on a flat surface with the lens pointing up (5) The lens should retract.
6) Turn off the camera
7) replace the media card and turn on.
I think the camera was getting hung up on the pictures stored in the camera's memory.
Aug 17, 2009 | Cameras
I cant put a 2gb digital card
hi
check out your fullfill there instructions
  • Supply voltage: 2.7V-3.6V
  • Durability: >10,000 insertion / removal cycles
  • Supports Content Protection for Recordable Media (CPRM) for music and other commercial media
  • Fully compatible with SD Card Association memory card specification standards V1.1
  • if yes ,
    try to format in fat file system with your pc or format with camera
    Aug 10, 2009 | Acer Cameras
    How do I use micro sd card in camera
    What is the orange "card" bundled with my camera and how do I use it?
    The “card," pictured below as packaged, is the MASD-1 card adapter.
    The MASD-1 accepts microSD and microSDHC media, giving owners the option to record to those cards or to xD-Picture Card media, which is Olympus’ preferred format.
    To use microSD/SDHC media in the camera, simply insert the card into the adapter and then insert the adapter into the camera's memory card slot.
    Mar 19, 2009 | Olympus Stylus 1010 Digital Camera
    Feb 10, 2009 | Sony Alpha DSLR-A100 Digital Camera
    Sony Alpha DSLR-A100 Digital Camera Logo
    Top Sony Cameras Experts
    james laughton
    james laughton
    JonSnell Electronic
    JonSnell Electronic
    Are you a Sony Camera Expert? Answer questions, earn points and help others
