I have two SD cards and each is supposed to hold 2gb. But they actually only hold a little over 1 gig. I need them to hold at least close to 2gb is there anything I can do to format it or something?
I've previously used them for my cannon camera and now I want to use one of them for a digital frame. Actually I am using it but it's only got half the pictures I want on it. I noticed this problem when trying to copy pictures from my PC to the card, it copies some and then errors out. When I then put that card in my camera the camera says memory card full.
yes, you can format, if you can get your card to show up as a drive on your pc through usb cable you should be able to right click the drive then choose format .. You will loose all info on the card though!!
Either that or i believe there maybe some dodgy cards being made. For example they may say they hold 4gb and show up on computers as 4gb but actually have considerably less space.
i can't access my list of pdf files. I need to delete some files but the application jumps from the...
(More)
i can't access my list of pdf files. I need to delete some files but the application jumps from the most recent pdf file I opened to the main menu
I cannot get my hotsynnc to connect to the internet. I have a palmone tungstenE2. I replaced the...
(More)
I cannot get my hotsynnc to connect to the internet. I have a palmone tungstenE2. I replaced the cable and reinstalled the software. Still will not talk to my computer. it keeps telling me to check my setup.
Palm Tungsten E2 will not turn on. I charged the battery and I pushed the reset button on the back....
(More)
Palm Tungsten E2 will not turn on. I charged the battery and I pushed the reset button on the back. I know the charger works because I checked it out with someone elses Palm.
So I have a nokia and whenever I turn it off and turn it back on it always takes forever to load up...
(More)
So I have a nokia and whenever I turn it off and turn it back on it always takes forever to load up the screen and my messages and phonebook I just want to know how to fix this problem it's really annoying please help.
