Question about Engel Refrigerators
SAMSUNG FRIDGE FREEZER RSH7UNBP NO ICE ,BAR MISSING ON 1ST DIGIT ON FREEZER TEMP READ OUT AND E DISPLAYED ON FRIDGE TEMP READ OUT
SOURCE: freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Posted on Apr 01, 2008
Agent Don
  • 310 Answers
SOURCE: Fridge/ Freezer not cold
My fridge started making a weird noise not too long ago. Now the fridge isn't cold and everything in the freezer is melting. The read out still says that everything is the right temp, but the melted ice tells me otherwise. Recently my daughter found out how to operate the buttons and has been pushing them a lot, but we change them quickly.
I would have the refrigerator / freezer checked out by a serv tech mainly because if it is a compressor, this would not be something that can be done by as customer, but it could be something internal like a fan or a fan motor that blows the cold air or a bad thermostat or sending unit – the weird noise is something internal that really should be check out by a serv tech before you lose everything as far as food, etc. – the refrigerator is a sealed unit and is hard for a customer to service unless they have serviced the unit before.
Posted on Apr 15, 2008
SOURCE: Samsung twin cooling fridge/freezer model
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Posted on Aug 01, 2008
SOURCE: samsung rs21dcns fridge freezer Ice
Found an electrical drawing and resolved the issue - Broken cable
Posted on Nov 11, 2008
projdoc
  • 2237 Answers
SOURCE: 2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Posted on Aug 28, 2009
Control on door has flasing lights, water and ice has stopped working
this appears to be the door switch is either bad or disconnected and has triggered an alarm mode to the display. If the unit is cooling ok then you should remove and check the switch with a meter.
May 29, 2014 | Maytag MFD2560HES Bottom Freezer French...
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Temp sensor
Check for broken wires on your ice maker temperature sensor. On my model RF265AABP that was the problem causing display to read 88 88 with one digit blinking.
Jun 29, 2013 | Samsung RB217ABPN Bottom Freezer...
Hi, my side my side fridge freezer has just packed up, the temp reads cold enough but the fridge and the freezer parts are both warm :( plz help
While it could be the main control board, I would check for a defrost circuit failure first. If you take off the read shield of the freezer you will be able to see the evaporator coils. If that is a block of ice, then your defrost circuit is not doing its job and the ice is causing the thermostats to read the incorrect temperature.
The good news is that once you defrost the unit, you will have 2-3 weeks before the ice builds up enough to be a problem again. Which give you time to troubleshoot and order the replacement parts.
Jan 28, 2012 | Samsung Refrigerators
I have a Samsung refrigerator with a bottom freezer. The 'fridge and freezer temp settings are displayed on a panel between the upper and lower doors. The unit is about 4 years old. About a year ago,...
Hi adc3,
If the display has stopped working, it is often caused by a blown fuse. Please locate the main control board and check if there's a fuse that may have blown. For the ice maker issue, please check if the ice maker has been turned off. You can check it by looking for a wire that looks like a coat hanger that is located at the right side of the ice maker. Ensure that this wire is not in the raised position. If it is turned off, just simply lower the wire to the down position to turn on the ice maker. If this did not work, please check the tooth on the drive or driven gear of the ice maker. If you noticed a broken tooth you should replace the ice maker.
Hope it helps.
Thank you for using FixYa.
Jun 14, 2011 | Samsung RF265AA Bottom Freezer French Door...
Freezer was freezing ice cream rock hard and refrigerator liquids( ie. milk, beer) was only a little cool. how should i adjust the number settings?
Don't do anything too quickly here. Move the freezer number one digit warmer and fridge one digit cooler today.
Check temp (and icecream) tomorrow. If not satisfied, move one more digit on the freezer or fridge until you are happy.
Mar 18, 2010 | Maytag MSD2756G Side by Side Refrigerator
Fridge temp goes up and ice forms in fridge
CHECK THE BAFFLE IT MIGHT NO BE OPENING OR CLOSING PROPERLY, THAT`S THE SMALL DOOR LOCATED @ THE LEFT UPPER CORNER OF THE FRIGERATOR
Aug 19, 2009 | Samsung Refrigerators
Samsung, american style fridge
hi lemmy, i will find out from samsung tech and get back to you, this is an unusual prob,,
Jun 04, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
116 people viewed this question
Top Engel Refrigerators Experts
Jaime Hernandez
christian nielsen
cwradio73
Are you an Engel Refrigerator Expert? Answer questions, earn points and help others
