Question about Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL15 washer wont turn on I do have power to machine but no light to controls. Problem started with machine would all but shut down when got to rinse cycle so started to run diagnostics test as stated by the instructions found behind control panel when machine shut down completely. Any advise?
ngfam1
  • 639 Answers
SOURCE: Fisher Paykel Smart Drive 051
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
SOURCE: My Fisher & Paykel GWL15
Throw it away and buy it new one
Posted on Dec 30, 2008
  • 51 Answers
SOURCE: Fisher and Paykel EcoSmart GWL15 Machine won't
It sounds like you need to re programme the machine.
With the machine plugged into the wall and turned on and the headset turned off this is what you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Posted on Jun 14, 2009
TheMobilian
  • 8220 Answers
SOURCE: F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Posted on Dec 31, 2009
  • 713 Answers
SOURCE: I have the Fisher & Paykel EcoSmart GWL15
Hi just read your posting.Now from the information in your posting the lights that are lit,starting from left to right are the 3rd, the 6th and the 8th,is this correct.If it is correct then the fault on machine is called PUMP BLOCK ERROR.Now 1st thing to do is to bail some of the water by hand with a small pot or bucket, enough to lean the machine back so you can look under the machine.When you are able to look under the machine look to the front right and you should see a black fan.This is your pump.Turn the fan clockwise and anticlockwise a few times to loosen the pump.The fan should turn freely.Then put the machine back upright and select a spin cycle.The machine should start draining.Please reply back on how you went or if you have the newer style of pump or if the machine stills does not drain.
Posted on Sep 07, 2010
Fisher & paykel washing machine has no power
it was probably the pump shorting / overheating, and running it has caused it to blow the fuse in the motor controller.
Nov 08, 2013 | Fisher Paykel EcoSmart GWL15
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
Sep 30, 2009 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel EcoSmart GWL15 Machine won't agitate or spin - two yellow lights come on, and machine beeps every second or so. This happens even with the power off.
Jun 12, 2009 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Power wont go on fisher paykel eco smart GW11
first step is to make sure you do have power to your washing machine.
if you press your power button and you dont get any response,you will find the your electronic have gone.
Its called a power module.
They do have fuses in them.
Jul 31, 2008 | Fisher Paykel EcoSmart GWL15
My fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Jun 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
821 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
