Question about Samsung LN40A650A LCD TV
Samsung tv lcd40 keeps rebooting and all you see is black screen and hear start up melody was working just fine then this started
  • 34 Answers
SOURCE: Samsung LCD flat screen goes black. Turn tv off
Sounds like your power board is failing. contact samsung tech support and describe your problem. some parts on samsung have lifetime warranties and the service call is free.
Posted on Apr 09, 2009
  • 22 Answers
SOURCE: Samsung LCD tv hpr4252x/xaa not working
Did you check the video plug?
Posted on Jun 14, 2009
  • 304 Answers
SOURCE: Screen goes black nafter start up. What can I do?
You probably have some bad buffer boards as well as a bad Y-main bd and or a bad X-Main bd. Have a trained samsung tech troubleshoot the set.
Posted on Jul 17, 2009
SOURCE: Fault with Samsung PS42S5H
sounds like the lower y-sus buffer! take off the back and give me the pcb number should start with Lj92
Posted on Aug 30, 2009
  • 453 Answers
SOURCE: my 52 inch samsung flat screen has a black
u may have a bad lcd panel or s/t-con board , but first check power supply for bad capacitors
Posted on Apr 14, 2010
My galaxy tab A keeps booting on start up like it keeps showing Samsung and keeps repeating? How do I fix it?
Plug into charger hold power button down until device powers down
charge fully then disconnect and power up
might work or look at this site to erase cache entirely
https://appauls.com/how-to-fix-the-samsung-galexy-tab-reboot-loop/
Nov 04, 2016 | Samsung Tablets & eReaders
We have LCD 550 Samsung Model# LN32A550P3F bought it 5/5/2008 has worked great until last night it turns on led backlite comes on the melody plays red lite flashes and screen is black we brought another tv...
Don't waste any time on this. Being only 4 months old, it should still be under warranty. Request warranty service or exchange. The power supply module has a problem or the main processing board is telling the power supply to shutdown. In either case, a board change is necessary and should be covered.
Dan
Sep 24, 2008 | Televison & Video
How do I turn off the starting sound on a Samsung series 7 tv?
On your Samsung remote. Press the MENU button. At the botttom of your screen you have the setup selections. Scroll over to the SOUND option and select that, A menu should appear and toward the bottom of the menu you should see MELODY. Scroll down to that and select ON or OFF...
Nov 02, 2014 | Samsung UN50ES6500 Series 7 LED 3D 1080p...
SAMSUNG TV- model: HLN4365WX/XAA: Component 2 mode not supported
One thing to try is whatever (a box?) connected to that input--remove power from for a short while and then plug back to see if that will reboot the unit connected there.
May 23, 2012 | Televison & Video
How to turn off melody on a samsung 7100
http://downloadcenter.samsung.com/content/UM/201009/20100906141849812/[UC7100-NA]BN68-03151A-01L03-0903.pdf
Looks like you press Menu and then Setup on your remote. Page 27 discusses the melody settings. You can either turn off the melody or enable "Fast Start" which will automatically disable the melody.
May 04, 2011 | Samsung Televison & Video
How do I turn off the on / off melody on the 42 in samsung LCD tv?
Usually melody turn On-Off option is available in Settings menu of tv, let me know model number of your tv to provide you more detailed info about how to turn Off melody sound on start up and shut down.
Thanks.
Nov 07, 2010 | Samsung HCN4226W 42" Rear Projection...
The volume is not working on our Samsung HPT4254 Plasma. We have a RCA surround sound connected to it as well as our cable box.
First check to make sure that the audio isn't "Muted". Second, Go into the user menu and check to make sure that the "Melody or Chime " is turned "on". Third, Turn the volume up half way.Fourth, Turn "off" the set. You should hear a "Down" Melody or chime. Next turn "on" the set. If you did hear the Melody when you turn the set "on" or "off" then the audio system in the set is ok. If you did not hear the Melody then the Main bd needs to be replaced. Have a trained Samsung tech repair your set.
Jul 12, 2009 | Samsung HP-T4254 42 in. Plasma Television
Jul 02, 2009 | Samsung HP-S4253 Television
Acer will not start up properly; "pulsing" On and Off
Hi Melody, Try removing the battery with the AC unplug for a couple of minutes (an hour preferably). Try with just the AC adapter only with no battery and see if it works; try with the battery only and see if it works, try with both the battery and the AC adapter and see if it works. If none of the above will make it work, then you have probably a hardware issue or BIOS power saving issue. Post back results of the 3 tries and will figure something else. Good luck and kind regards.
Sep 03, 2007 | Acer Aspire 5050-3242 Notebook
Samsung LN40A650A LCD TV Logo
22 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
