Question about Frigidaire FRS26ZSG
Changing ice maker for fridadire part # FrS26zrg
Ice maker not working, just changed the filter for the second time , now what
  • Frigidaire Master
  • 4,654 Answers
Can you add water to the ice maker from tap water, Allow the water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water will point to your as the problem=> 218658000 Water Inlet Valve
If the ice maker sits there with ice and does nothing the problem will be the ice maker=> 5303918277 Ice Maker Assembly
I will be here should you have questions, Thanks Sea Breeze
Posted on Dec 08, 2012
catriver
  • 878 Answers
SOURCE: slow water flow
dadcanfix. There are two possibilities here. One could be the water valve itself, clogged or not seating or opening properly. The second would be the water tank on the refrigerator side, partially frozen. I believe they have a kit now with coiled tubing that replaces that tank because of the trouble they had with it. Remove the refer drawers and take a hair dryer and go over the tank lightly. See if that improves the water flow. Catriver..post back.
Posted on Mar 21, 2007
  • 92 Answers
SOURCE: 10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Posted on Oct 31, 2007
aborcass
  • 2651 Answers
SOURCE: Amana French door Refridge-water dispence inside the door not working
pull out crisper and deli shelf thers a tank behind them its probably froazen, hit it fora few minutes especally around top neck portion with a hair dryer, common issue
Posted on Feb 23, 2008
  • 449 Answers
SOURCE: ice maker and water dispenser does not work
Check the inlet for clog, also check to see if you're fitting the filter right. the part where you have to press to release the filter should come back to it's normal position when you insert the new filter.
Posted on Dec 17, 2008
  • 3 Answers
SOURCE: ice maker on frigidaire not working, changed
how cold is the freezer?
Posted on Feb 27, 2009
Ice maker no longer making ice after changing filter,GE Eterna ESS25LG refrigerator
recheck filter install is water valve on and is ice maker itself on
Jul 24, 2016 | Refrigerators
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
Power surge caused appliance to go out. refrigerator ice maker now not making ice. has water on but no ice help
Reset the ice maker:
Locate the switch next to the water filter status light.
Press the light switch five times in 10 seconds or less.
Wait for the status light to change from red to green.
Mar 02, 2015 | Whirlpool Refrigerators
Frigidaire Gallery French Door Refrigerator ice maker not making ice
You can search with your model number to see if a filter is available or not. Secondly unless the ice maker was damaged for sure it's likely that the fan is not running in that compartment or air is leaking into the refrigerator and making the ice maker think its not cold enough to make ice.
Apr 13, 2013 | Frigidaire Gallery 25.8 Cu. Ft. French...
pour water in your ice maker. when it dumps ice cubes, keep filling it up again.after 5 or 6 times it should start working on its own
Oct 21, 2012 | Frigidaire Refrigerators
No water no ice
Change the=> 67006531 Water Inlet Valve I believe the side of your 67006531 Water Inlet Valve that controls water flow to the ice maker has weakened and cannot open properly. Replace the water valves and I believe the ice maker will work fine, Sea Breeze
Jun 07, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
NO ICE
Check this first,
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
ice and water dispensers. To turn off the ice maker, see “Ice
Maker & Storage Bin.”
 Press and hold LOCKOUT for 3 seconds to lock the
dispenser.
 Press and hold LOCKOUT a second time to unlock the dispenser.
Let me know if this helped, Sea Breeze
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Changed filter, red light flashes, not making ice at all
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kjkjl
Aug 08, 2008 | U-Line Refrigerator Ice Maker
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Refrigerators Logo
165 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
