Question about Sterling Audio ST51 Microphone
My st51 mic is not pickin up sound with my fast track pro
Im using pro tools mp 9 and i just bought this mic and i cant record no sound what should i do
2 Suggested Answers
  • 5 Answers
SOURCE: im not sure if its
First, Make sure you are speaking into the front of the microphone. there should be a logo or brand name at the front to show you. because of the cardioid pattern, sounds behind the mic are not picked up; good if the sound you want to isolate is at the front, not so good if it's at the back. Second, make sure the gain on the fast track is turned up. And third, try using a different program. It's unlikely to be the problem, but if it is, it's an easy fix.
Posted on Jan 20, 2011
I am using pro tools 8 LE. I have a blue bluebird condenser microphone. the cable going into the mic is a male 3 pronged end. and the end going into my avid mbox mini is a normal ending (the ones that look...
The mbox mini is usb powered, wont work without power so your mac or pc must be powered on and connected. The blue led will be on when powered. Assuming you have the the appropriate cables, you want to make sure the condenser is plugged into the Mic/Line input. (Input 1 on the back of the mbox mini). All condenser mics require phantom power, so engage the +48V switch. Also make sure the DI (direct input) switch is not engaged. The input gain control is located on the front of the mbox... There needs to be speakers connected to the 1/4 output jacks on the back of the mbox or headphones on the front for sound output. Use the large knob for monitor volume control.
In protools: Create a Stereo Master fader track
Create a mono audio track
Set the input of the mono audio track to Mic/Line 1 Arm the track for record (click & make sure the R is red)
You should getting levels and sound output from your condenser.
Apr 01, 2011 | Blue Microphones Blue Bluebird Condenser...
I have a mxl 990 microphone and its hooked up to a Pro tools LE 8 Mbox Mini . when im recording on protools or any other software with this mic, i hear a static/popping sound and it records the popping...
Try increasing the latency. Depending on your computer, it may not be able to handle low latency levels. Latency is a measure of the delay between the time you make a sound and the time the computer records that sound. With the Mbox mini, the unit for latency is the number of samples the driver collects before sending them to an application as input. Lower latency can make recording easier and more accurate, but not all computer systems can operate at the lowest latencies without introducing noise. Open the Mbox mini dialog and select the latency tab. experiment with higher latency levels and see if it goes away. somervta_0.jpgThis is what the dialogue might look like. another solution would be to try a different DAW. I had the same problem with my Fast Track Pro in ProToolsand it worked fin on Reaper, Garageband and Logic.
Jan 17, 2011 | M-Audio MXL 990/991 Recording Mic Duo and...
Im not sure if its a mic problem or an interface(m-audio fast track) or even if its the program im using (adobe audition 1.5) but when i record using the sterling ST51 it sounds like im about two miles...
Jan 15, 2011 | Sterling Audio ST51 Microphone
My st51 is only recordin to one side of the audio track...how do i fix this
either one of your mics has burned out or more commonly the cable to one side either at the mic or plug has come off check the conections
Dec 06, 2010 | Sterling Audio ST51 Microphone
No recording?
The static after several seconds seems like this is a problem with certain versions of OS X. You might be able to fix it by downgrading or upgrading. Apple Forums say that it's fixed in 10.5.6.
You can double check that this is the problem by trying it on a Windows computer.
Jul 28, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Taking recordings from mixing desk
As the Fastrack can only receive one audio signal at a time you would have to record each track seperatly into Pro Tools.
I'm guessing your mixer is a multitrack recorder.
Solo track 1 on the multitracker and playback from there into the Fastrack, with track 1 on Pro Tools set to record. Repeat this for each or your tracks on the multitracker.
When you've finished you'll need to align all the tracks in Pro Tools so they all playback in time with each other.
Jun 25, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Hello, i am new to recording music on my pc and need help! i bought a microphone, an m-audio fast track pro and have a guitar and a voice! bundled with the fast track pro was ableton live lite and...
get straight into protools. it is worth learning in the long run, and most studios operate on it also. you can take you tracks into a studio then to work them up more. It is great software for editing audio and so on and sounds great. there are heaps of quick start guides on line to use it also. check here. If you are serious about your tunes... then just get into it and learn Pro Tools. It worthwhile
Apr 18, 2008 | Audio Players & Recorders
Help
need pre amp with it boost ya and to get it in sterio way should be are u running it direct in usb port and u have usb 2.0 outlets corect
Jan 10, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson G-track
It's supposed to only record on the left side. When it's in "INST/MIC" mode the left channel has your mic on it and the right channel has your instrument, so you can mix them separately. Just configure your recording software to put the left channel on one track and the right channel on another track.
Sterling Audio ST51 Microphone Logo
Top Sterling Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sterling Audio Player and Recorder Expert? Answer questions, earn points and help others
