Question about Panasonic DMR-E55 DVD Recorder
Remote dvd 2
This is what comes up when i use the remote cant enter any menus what can i do
  • good2bbak Nov 08, 2007
    my remote is doing the same is there a solution to this
The solution for this problem is you have to hold the enter and button 1 or 2 for more than 15 seconds it worked with mine.
advice come from panasonic hope this helps.
good2bbak.
Posted on Nov 21, 2007
  • jeff knowler Sep 30, 2011
    yes this works...thanks i was starting to pull my hair out "!!
  • 28 Answers
There is sometimes a switch on remote controls to differntiate if you have the same model or make of the machines.
So you set them a DVD1 or DVD2 etc., this way you can operate two machines one at a time and not both responding to one command.
Have a look on your remote if not there then look into your op manual.
Regards
capital98
I HAVE A MITSUBISHI (MEDALLION MODEL TV).THE V-CHIP IS ON AND I CANT RELEASE THE V-CHIP BECAUSE A CODE IS NEEDED. IS THERE AN OVERRIDE CODE THAT CAN BE USED TO CLEAR THE VCHIP?
Mitsubishi sets use a four-digit code for a V-Chip locked program, view a locked TV, cancel the lock, or to enter the V-Chip lock menus. You can view the locked shows on the TV set by pressing the number 9 and QV buttons on the remote at the same time, whenever your code is requested. This process temporarily unlocks the TV and asks you to enter a new code.
Oct 02, 2008 | Mitsubishi Televison & Video
I have a Samsung HTC 550 home theatre system. It's set to region one and I've tried everything to make it region free to no avail. I want to watch a region 2 DVD. Can you help??
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and unplug from power. wait 30 seconds (this clears RAM)
4. Reconnect to power.
5. Turn on player with remote.
6. Press ENTER on remote. (ignore message on screen)
7. Press 8, 4, 2, 6, 9 using keys on remote. (if your player is already set to region 2)
8. Press ENTER on remote.
9. Wait until player finishes processing. (approx 15 seconds)
10. Turn off power from remote.
11. Turn power back on with remote.
Player is now Region Free.
or
Turn on with remote control without disc.
When message "No disk" appears, press on the remote,
ENTER,
8,4,2,6,9
ENTER,
If hack work after the second ENTER player will power off automatic.
When power on again this was region free, I can confirm now read region 1, 2 and 4.
Sep 08, 2016 | Samsung HTC-550 DVD Home Theater System
Uniden DECT6.0 Model D1680 Problem: Need to change recorded message ,cant get past Security Code_ a 2 digit pin .Forgot what is was..
The only time the Security Code is used is to effect
Remote Access, ie, "call home and manage your
answering machine messages remotely" by pressing
the code numbers while the Greeting is being said....
The Security Code is set on the D1680 from the handset
by this procedure:
press [menu]
scroll to "Ans. Setup"
press [select]
scroll to "Security Code"
press [select]
the code will be displayed, first digit blinking
(enter a new digit if you want to change it )
the code will be displayed, second digit blinking
press [select] (chirp) press [END}
All of the Answering Machine System functions can
be managed remotely, and voice menus are provided
to guide you in these operations.
Entering the model number found on a small sticker under
the battery in the handset at www.manualslib.com will
fetch a free copy of the User's Manual in case the original
has been misplaced.
Apr 01, 2016 | Uniden D1680 Cordless Phone
Panasonic DMR-EZ28 has RC2 display /l cant see an enter button to try pressing 1 then enter
the unit has been changed to remote control 2 mode. Look in the owner's manual and change the remote to mode 2 and you should be fine.
Feb 20, 2015 | Panasonic Televison & Video
My tv has subtitles and i cant turn them off! I have at&t u verse and a phillips tv any help at all? I don't have the original remote just the one from at&t!
It is in either the set or coming from the box you seem to be using---look in both menus---if no philips remote that CC got turned on somehow.............
Aug 26, 2012 | Televison & Video
Dont have a remote and can't hide the subtitles
Ms. Padilla, you need to enter the menu settings in your television, should be a menu button on you tv set. Once in menu go to picture or scroll through the menus untill you find caption, once you locate that you can turn the subtitles off.
Aug 23, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Remote control service code numbers to enter service screen to begin alignment
If you tell me here the model number I will get the code if possible.
the sets they made had two hidden service menus for Convergence and Alignment and both are entered using the original remote (universal will not cut it).
Apr 01, 2012 | Philips Televison & Video
V-chip block passcode
Hello
You must have its original remote control handset to unlock your Mitsubishi tv.
After you set the lock, you must use your pass code
to view a locked program, view the locked TV, view
a locked channel, cancel the lock, or enter the Lock
menus.
If you forget your pass code, you can view the locked
TV without entering your pass code. When you are
prompted for your pass code, press the number 9 and
QV keys on the TV remote control at the same time. This
process temporarily unlocks the TV.
When entering the Lock menu, this process deletes
your old pass code and prompts you to enter a new
pass code.
• You can either enter a new pass code to open the
Lock menu and make changes or press EXIT to close
the menu.
• If any of the locks are turned on and you exit the
menus when prompted for a new code, the old
code and all lock settings are retained.
• If all locks are turned off and you exit the menus
when prompted for a new code, then the previous
code is erased.
OK.
Mar 17, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I dont know which code to use on my rca remote to operate my vcr. I cant use it without it
RCA universal remote codes are available here: http://rcaaudiovideo.com/remotecodefinder/ . Enter the model number of the remote and then VCR in the drop down menus. Then find your brand in the list.
I hope this helps.
Mar 13, 2011 | RCA Universal Remote Control
Panasonic DMR-E55 DVD Recorder Logo
279 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
