How to remove hard drive from sony vaio pcg-2c1l
  • 27,725 Answers
As you install new programs, rip music files from CDs or download data from the Internet, the hard drive on your Sony Vaio PCG laptop will eventually fill up and run out of room. You can replace the hard drive with a new one that has a larger capacity.
Power off the Sony Vaio PCG laptop, disconnect the power cord and then close the lid. Flip the computer over so that the bottom is facing up toward you. Press down on the raised latch that holds the battery into place and then pull the battery out of the laptop. Locate the five screws arranged in a square pattern on the right side of the laptop case. Take a screwdriver and remove all of the screws. Slide your fingernail or the tip of the screwdriver underneath the seam of the square plastic cover and lift it up. Grab the cover and remove it. Pull out the two screws that hold the hard drive onto the motherboard. Grab both ends of the hard drive and carefully pull it directly upward for about an inch so that you can see the cable connected to the motherboard. Disconnect the cable and then pull the hard drive the rest of the way out. Take out the four mounting screws that are located on both side edges of the hard drive. Take the replacement hard drive and install the mounting screws into its left and right sides. Plug the cable that runs from the motherboard into the corresponding port on the replacement hard drive. Check the direction of the new hard drive and lay it into the open slot in the same direction as the old hard drive. Use the two screws you pulled out earlier to hold it in place. Slide the cover piece back on and replace the five screws. Push the battery back into the laptop until the latch snaps into place. Hope this helps.
Posted on Dec 08, 2012
  • 16 Answers
SOURCE: Where is the best place to get a new hard drive
You're on the right track--it doesn't need to be custom-manufactured for Sony notebooks--just needs to be an internal mobile IDE-PATA hard drive. Still, I would recommend at least looking for something name brand with a decent warranty. Amazon and Newegg.com both have the Western Digital WD2500BEVE (250GB) for $79.99. That's a decent price (not mind-boggling), but more importantly it's a solid size/price reference point--e.g., if you find a 500GB name-brand hard drive for the same price, pull the trigger immediately.
Posted on Mar 29, 2011
jyackle5
  • 8197 Answers
SOURCE: how do i replace the hard drive on a sony vaio
on the bottom of the laptop where the battery is there are different panels under one of those panels is the hard drive the panel will be about 10cm to 15 cm long.
Posted on Dec 24, 2009
SOURCE: pcg-fx802 motherboard dip switch settings
sw 1;2;4 --> 2 up on
sw 3 --> 4 down
Posted on Oct 31, 2009
SOURCE: I want to Down DRIVERS for Sony VAIO Version PCG-7L1M
jshajhva
Posted on Jul 22, 2009
SOURCE: how to reformat my sony vaio PCG-7L1M
abcd
Posted on Sep 26, 2008
SONY VAIO PCV-1112 CANT USE KEYBOARD OR MOUSE
Please test it using other USB keyboard and USB mouse, and see the device status in the Control Panel (Control Panel, Device Manager). Is the keyboard item missing? Is there any USB item with an exclamation mark?
Feb 18, 2014 | Sony VAIO PCG-505 PCG-671L PCG-700...
How to remove a hard drive from a sony vaio pcg-6n1l
Turn laptop over and remove screws from HDD compartment door.. Remove screws holding HDD in place and remove.
Nov 22, 2013 | Sony VAIO PCG-6N1L, PCG-6N2L, PCG-6N3L...
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
I need to replace my hard drive in my Viao PCG-GR370 laptop. Is it possible to put in a larger than 30 GB drive?
below is a link for a 320 gig hard drive for your model, i hope this helps
http://www.upgradecomputermemory.com/ram.cfm//memory/s/sony-vaio/sony-notebooks-vaio-pcg-series/VAIO-GR-PCG-GR-Series-Notebook/VAIO-PCG-GR370/320GB-Notebook-Hard-Drive-for-the-Sony-VAIO-PCG-GR370.html
Feb 14, 2011 | Sony VAIO GR370 Notebook
How can I remove the hard drive from a Sony VAIO PCG-F305?
Remove the keyboard also,there's usually some more screws under the keyboard.
Oct 17, 2007 | Sony VAIO VGN-S460 Notebook
Open Questions:
Computers & Internet Logo
594 people viewed this question
David Payne
David Payne
