Question about Canon MF8180C Color Laser MFC Printer
Printer error E 021 mfc 8180c canon - Canon MF8180C Color Laser MFC Printer
5 Suggested Answers
  • 39 Answers
SOURCE: how to fix canon code E071
Here is an answer from DZJOLLA:
"hi there
well ive had years of experience on these machines and seen this error loads so ure in lucksmile.gif
1st off are u a tech? if not do not read any further as this post will only make sense to a tech.
i can only imagine this machine is old now. most of the time its the connectors that cause the e071 error. how many prints has copier done? have the connectors on the carraige frame and on frame of machine ever been changed? if not thats more than like causing your issue.
is your TD unit spinning ok? or is there resistence somewhere, if so this might also cause this error. the manual points to the 3 timing sensors in the TD unit IE. timing plates arent arriving on time for those sensors, but again everything relates back to the connectors as this is where it gets its voltage from. blow the sensors out as well.
change the connectors mate would be my 1st conclusion for that errorsmile.gif let me know how u go please...
the other errors arent even coming up in the manual which points even more to the connectors.:
Posted on Apr 28, 2009
IB4G2008
  • 3587 Answers
SOURCE: Canon Image Class MFC 8180c "Download Stanby"
that's not too good...let's get down to cases here
Posted on Mar 04, 2008
vkyhunk
  • 156 Answers
SOURCE: E002 message won't go away, printer won't work!
Hey Hi!i!ii!i!i!i,
Firstly Insert The Printer's Driver Software Disk In The Computer And Completely Uninstall The Printer Driver Software. Don't Remove It From Control Panel. You MayUse Any Uninstaller Software For Removing the Printer's Driver SoftwareAnd If You Don't Have The Printer's Driver Software Disk.Here's The LinkFor Uninstaller Software. ( It Will Work Only With WINDOWS OPERATINGSYSTEM)
http://wugnet.com/shareware/spow.asp?ID=638
Then Clear The Temp And Prefetch Files.
Disconnect the printer's cable form the back of the computer and disconnect printer's power cable and turn it off.
Press and hold the printer's power button for 30 Seconds then release it.
Turn off your computer and then disconnect all the cables from the back of the computer.
Press and hold the computer's power button for 30 Seconds then release it.
Wait 2 minutes.
Hook up monitor, mouse, keyboard, internet connection and power cable and then restart your computer.
Hook up printer's power cable and then turn it on.
Hook up printer to the computer.
Copy and paste the link below in your internet browser and then download and install the LATEST PRINTER'S DRIVER SOFTWARE AND FIRMWARE AVAILABLE, IF ANY..
WINDOWS XP
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=10561
WINDOWS VISTA
FOR ANY OTHER OPERATING SYSTEM KINDLY CHOOSE THE OPERATING SYSTEM.
Restart Your System.
Issue Resolved.
Feel Free If u need any further help.....Kindly Rate Solution..
Posted on May 28, 2009
fanaudi
  • 1381 Answers
SOURCE: I need Driver of canon
Hi rosenfeldhen
You will find your driver here :
http://www.canon.co.uk/Support/Consumer_Products/products/Fax__Multifunctionals/Laser/LaserBase_MF_series/LaserBase_MF8180C.aspx?type=download&page=1
Best regards ,
fanaudi .
Posted on Jul 18, 2011
Canon imageCLASS 8180C
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload : -http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Jul 09, 2012 | Laser Canon imageCLASS 8180C Multifunction...
Error message E078 on Canon MF 8100 series after replacing drum
try to check your connection form your printer and if possible try reinstall the printer driver then try to run again the printer.
Jun 16, 2009 | Laser Canon imageCLASS 8180C Multifunction...
Error E078 Canon MF8180c
I have a Canon Color Image Class MF 8180C with a system error code E078 - Trying to understand what it means and how to clear. Any ideas?
Jun 05, 2009 | Laser Canon imageCLASS 8180C Multifunction...
Canon ImageClass MF 8180c Error Code E071
i had the same problem, had to replace the drum unit
Mar 10, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
I have a Canon MF8180C showing me Download Standby.M/c is locked out?
i don't have sofware cd for this printer canon 8180c. i want download the program, i want to know how i can do that
Dec 07, 2008 | Canon MF8180C Color Laser MFC Printer
Looking for scanning software that will work well with Vista 64, and a Canon MF 8180c. A printer driver came with a scanner driver, which works with paint. But I am looking for a ADF friendly software...
problem is, the toolbox utility (scanning) from canon is not recognizing my 8180c, even though i just dwnd fresh driver from canon for local printer. (toolbox is a wired utility.) so no answer, just bewilderment. used to work!..
Nov 12, 2008 | Office Equipment & Supplies
Canon 8180C laser Multi Function printer Error Code 078
did you reset the drum unit on maintanance counter of the machine?
Apr 18, 2008 | Canon MF8180C Color Copier
Canon MF8180C Color Laser MFC Printer Logo
220 people viewed this question
old marine
old marine
