Question about kawasaki Full Suspension Mountain Bike Men
No spark wont start
I just replaced the coil and regrounded the grounding clip on my 1995 Kawasaki Bayou 400 ATV. It ran for about 5 minutes and now I have no spark again. Tried to replace the spark plug but that didn't solve the problem. Where can I look because it seems like an electrical problem.
Thanks Nick
Minnesota
  • birlo2020 Feb 26, 2009
    i have kawasaki 17 hp wont start no spark i replace the ignition coils the module still no start
  • kcnelson Mar 03, 2009
    i have the same problem changed plug and now it won't even turn over, battery is fully charged and new, anything simple to try before getting right into it
I have a 2007 kawasaki brute force 650 4x4i... my problem is , i recently change and reset the beltlight... now the bike starts run for a bout 1 minute and stop. What might the problem be?
Posted on Apr 07, 2011
Hey i had a similar problem a liitle while ago on my yamaha,i disconnected the kill switch wire then i had spark(faulty kill switch)
Woth a try,cheers, Alan.
Posted on Jan 30, 2009
No spark at plugs
Posted on Mar 11, 2009
My Kawasaki kvf 400 4 wheeler wont start because the neutral light wont come on even if it is in neutral. it pull starts fine
There should be shift sensor there or a shift actuator to check.
Some Kawi manuals if you need them: Kawasaki ATV
Jul 15, 2017 | kawasaki Motorcycles
1988 klf300 bayou no spark, installed a new cdi voltage regulator,stator,and coil ran for four days and now no spark. what do you think is wrong.
Hi, Jeff sounds like you have a faulty wire connection somewhere otherwise the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Another no spark bayou any help left out there
Kawasaki Bayou 300 spark problems
https://www.tradebit.com/usr/valuablemanuals/pub/9003/1986-2006KawasakiKlf300Bayoufree.pdf
OEM Parts for Kawasaki
1988 Kawasaki Bayou 185 Owner Manual
Jan 14, 2017 | Motorcycles
Kawasaki bayou klf300b atv centrifugal clutch nut removal
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Kawasaki despair not, for a mere $5 you can download another one. For more information about your issue and free valuable downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.kawasakimotorcycle.org/forum/kawasaki-atv-mule/138652-bayou-220-primary-clutch-nut-removal.html
Project Bayou 300 44 Clutch Repair
Bayou 300 Centrifugal Clutch Endplay Question
https://www.tradebit.com/filedetail.php/118245427-kawasaki-bayou-300-service-manual-repair-1986-2006
Feb 28, 2016 | kawasaki Motorcycles
Kawaski bayou 300 stater wont engage engine all the time why
Hi, Gary you may have a starter solenoid or starter drive going south for more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
bayou 300 starting problem Kawasaki ATV Forum
1986 Kawasaki Bayou 300 Starting Issues
Kawasaki Bayou not starting
Owner Manuals Service Manuals Kawasaki Vehicles
Jan 25, 2016 | Motorcycles
1995 400 Bayou. How do I adjust the shifter?
Hi George, I am sorry you can't find the first and best tool you ever bought for your Kawasaki but despair not for a mere $15.00 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
1995 Kawasaki ATV Service Repair Workshop Manuals
Oct 07, 2015 | kawasaki Motorcycles
Kawasaki troubleshooting
could be a bad spark plug,a bad ignition coil,a bad coil lead.Start with those first and also check your ground wires
Jul 16, 2014 | kawasaki 2008 Bayou 250
Atv trouble shooting
poss overheating--carb needs rebuild--or need tune up
Jul 14, 2017 | ATVs
I have a kawasaki 300 bayou atv that has no spark out of the coil
NO SOLUTION JUST A QUESTION, I'VE REPLACED THE CDI BOX THE REGULARATOR, STILL NO SPARK.....HELP
Mar 31, 2012 | Motorcycles
Kawasaki 300 bayou won't rev up.
No guarantees but try this. Pull the slide from the throat of the carb. Now move the clip on the jet needle down one notch. This will richen the low end mix. Two notches may be needed but do one notch at the start.
Apr 30, 2009 | 1990 kawasaki ZXR 400
kawasaki Full Suspension Mountain Bike Men Logo
895 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
