Question about Dimplex OFC1500 Oil Filled Radiator Heater
Is it cheaper to leave my heaters on?
I've heard some people saying that it is in fact cheaper to leave an oil filled heater on for 10-12 hours a day, rather than have it come on twice, mornings and evening. Is this true or a myth?
  • Dimplex Master
  • 2,597 Answers
It works both ways if you are home it will give a constant heat , but is it safe in your place to leave it on while you are out .
Once they are hot they should cut out on the thermostat thus costing less to run .
Posted on Dec 09, 2012
2 Suggested Answers
EwingElect
  • 276 Answers
SOURCE: Dimplex oil heater FR24. 2400W oil heater. shorts fuse box
I would suggest that the element may have absorbed some mloisture whilst being left in storage for a period of time. You may need to take it to a local repairer to see if they can dry out the element.
If there is moisture in the element it is not safe to use, hence it trips your circuit breaker.
Posted on May 27, 2010
The heater shorted out, sparks, electrical smoke. Is it salvagable or should I replace?
Yes you could say it has died 18 years has been very good time to look for new . I don't think you will get parts for it now .
Feb 23, 2012 | Lakewood Oil-Filled Electric Radiator...
Bad Odor on the Lakewood Oil Filled Electric Radiator Heater
Pull the 4 small screws from top & bottom of plastic cover (2 under plastic tab on top, pry off) and then check ALL connectors and all wires. Chances are one of the leads has been overheating and smoldering (mine burnt wire off on lower Thermal switch.) You may need a KDS 301themal switch matching the one in your heater. Google for sellers.
Jan 16, 2012 | Lakewood Oil-Filled Electric Radiator...
My HZ 705 is leaking oil. Has there been a recall on this model? Is it customary for oil filled heaters to leak?
In my limited experience of oil heaters i can say that no, it is not customary for them to leak and i have heard of no product recall on this model. I apologise I am not much help but i would suggest you do seek expert advice from the manufaturer
Nov 16, 2011 | Honeywell Heating & Cooling
I replaced the thermostat,the car still over heats and the heater still does'nt blow heat. the sticker under the hood says there is a special way to add coolant is there? I dont have a services...
It's probably air bound. In my 51 years of working on cars I've never heard of a special way to add coolant.
I just put some in the radiator or the container, start the engine, wait for the thermostat to open,then fill it, leave the cap off so it won't get air bound while it's running.
If there is a bleeder valve on top of the thermostat housing, open that until there is a steady stream of coolant coming out, then close it and refill system.
If it still over heats, you might have a clogged radiator.
Sep 07, 2011 | 1995 Oldsmobile Cutlass Supreme
HAVE SOME RUST ON AN OIL FILLED RADIATOR HEATER. WHAT CAN I SEAL A LEAK WITH?
they are supposed to be welded so i wouldn't recomend patching with anything else and you would need more oil if it s been leaking throw away and buy new, it would probably be cheaper!
Nov 29, 2010 | Lakewood Oil-Filled Electric Radiator...
Oil-filled heater smelling
yeah they do that, time for a good cleaning, if that fails, I'd replace with a ceramic heater... they are cheaper safer and cost less to operate.
Feb 21, 2010 | DeLonghi TRD0715T Oil Filled Radiator...
Bought heater at a yard sale & says oil filled heater but dont know how or where to fill??
The heater should be per filled with oil and sealed allyou should have to do is plug it in and waite about 15 or 20 min for the oil to heat up
Dec 01, 2009 | Heating & Cooling
Lakewood oil filled heater model 5600/7 won't turn on.
I went to buy a new oil filled heater because mine was blowing the breaker. After I bought two, I heard the sales rep telling a customer to store the heater on it's side or upside down or give it a good shake to loosen the oil from the bottom. So, I went home and tried this...it may take a couple of times before it stops blowing the breaker, but it works.
Dec 11, 2008 | Lakewood Oil-Filled Electric Radiator...
Dimplex OFC1500 Oil Filled Radiator Heater Logo
125 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
