Question about Jura Capresso Coffee Makers & Espresso Machines
Rust on the heating element Capresso 259.03 H2O Plus Glass Water Kettle
SOURCE: how do I clean the heating elements in my swan tea
Been using this fix for many years:
Get a large jug of the cheapest white vinegar you can find, fill your teapot with it (make sure the pot is cool and do not turn it on!!) and let it just sit overnight. You will notice that the inside of your teapot will be sparkling clean. Vinegar is about 4% acidic and it is the acid that dissolves the scale. After you are done, save the vinegar for use with other items aroung the home like shower heads, just remember that it takes a lot of time in contact with the solution for this to work.
The mineral buildup is Calcium Carbonate, which is just simple water hardness. Unfortunately as water gets hotter, this chemical has more of a tendency to scale up. Just the reverse of what you would think. So keep the tea or coffee pot cool during the soak.
Posted on Sep 10, 2009
  • 9 Answers
SOURCE: MG32 Cordless Electric Kettle: Power light shows on my kettle but water does not...
sounds like there's water in the element. Empty it out and let it dry out completely for a few days, and then try it again.
If the element is a concealed element (ie- you can't see the coils when you open the lid up) then there's probably a water leak into the sealed compartment.
Contact the manufacturer for a recommended repairer.
Posted on May 23, 2010
SOURCE: I think I need a
Coffee Maker manufacturers rarely sell individual parts for the machine aside from filters and whatnot. I recommend replacing it.
Posted on May 11, 2011
  • 35762 Answers
SOURCE: the blue light on my Jura Capresso Kettle blinks when I try to heat water. Nothing happens.
THe heating element may have failed.
Posted on Sep 12, 2012
  • 267 Answers
SOURCE: My Breville water kettle stopped heating water. This is my second teakettle to do this. We have had this second kettle for about 2 years. We always were careful to make sure the kettle is off before
Unless you can take it apart and repair it yourself, it probably isn't worth the cost to have it repaired. There are several websites that sell parts, but you really have to be familiar with electrical circuits to diagnose it. Possibilities are:
1. It could be the thermostatic switch that turns it off as it reaches temperature. These are little devices with two wires connected and are in the base of the unit. these normally reset themselves but can stop working, especially if they have gotten wet.
2. It could be the cord to the unit with a wire broken at the base or the plug end.
3. It could be a thermal fuse; these are about 1/4 inch in diameter and may be hidden in an insulating sleeve near the element; they are sensitive to both heat and current.
3. It could be the element is burned out.
Link to a parts supplier is enclosed
Breville Kettle Parts
Posted on Feb 04, 2015
Repair Capresso CoffeeTEAM GS No heat Wont Pump Water
Check the elements. Unit heats water and forces that heated water out.
May 25, 2014 | Capresso CoffeeTEAM GS 10- cup Brewer and...
No light, no water heating
The heating element may have failed.
Sep 11, 2012 | Braun WK200 Electronic Water Kettle...
My teakettle is about three months old. I was thrilled with it and told all friends to get one. Suddenly it stopped heating the water. A green light goes on when i push it up to start and thats it. ...
Hi Nancy. There is a fuse or fuse like device in the bottom of your teakettle. There is also a temperature control switch which may be faulty. (if faulty, it is 'open' and the pot thinks the water is hot already) If you have a volt/ohm meter, you can probably find and replace it. You will need the replacement part and tools to install it, including pliers, screw driver and a crimp tool.
since it is three months old, you should consider contacting the manufacturer for relief on this matter.
Good luck on your repair and thanks for visiting FixYa.com today.
Jan 28, 2011 | Jura Capresso H2O Plus 259 Cordless...
Why does the water boiled in this kettle smell and taste chemically? Any boiled in a plastic kettle in my home is fine.
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Jun 01, 2010 | Morphy Richards 43072 Cordless Electric...
May 17, 2010 | Alessi MG32 Cordless Electric Kettle
I add water but it won't pump the water
check the heating element , with a test meter, hot water does not boil up to the cup if there is no heat ....
Mar 16, 2010 | Jura Capresso 454 10-Cup Coffee Maker
Whirlpool glass top stove
The glass top can be change, but be aware that if you have all your cooking element fixed togetter, this could cost plenty of $$$. If your heating element can be remove easyly, you are a lucky owner.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Red light's on... but no hot water!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Nov 06, 2007 | Kitchen Appliances - Others
Problems with Breville SK500XL Stainless Steel Cordless Electric Kettle
There's a thermal cutout that trips if the regular safety switch isn't enough. According to the manual, if the thermal cutout trips you have to send it back to Breville for servicing.
That may be what happened, if just letting it cool down and trying again didn't work.
Aug 13, 2007 | Breville SK500XL Stainless Steel Cordless...
Coffee Makers & Espresso Machines Logo
43 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Jim Goldsmith
Jim Goldsmith
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
