Question about Garden
Engine won't start and continue running except when I first start it.
  • 2,239 Answers
Couple of things here, this Honda engine will probably have oil alert, make sure there is enough oil in the engine, if not the oil alert will cut the ignition, also there is a removable bowl on the bottom of the fuel tap, check this for dirt.
Posted on Dec 08, 2012
Engine won't run
Cranks but won.t run, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Engine cranks but won start Troubleshooting tips
Diagnostic flowchart for car that won start or stalls Troubleshooting for...
Troubleshooting and Fixing Car that Won Start
No Start Diagnostic Basics EricTheCarGuy
Mar 22, 2016 | Cars & Trucks
Won;t start nothing works except lights and beeping sound when door is open where is the starter located
Do you know how to do electrical testing ? Engine Won Start No Crank Diagnosis Troubleshooting Starting System Issues No Crank Troubleshooting engine does not crank The starter is under the vehicle bolted to the bottom of the engine ,most usually > Some car makers hide it under the intake manifold in what is referred to as the valley on V - engines . The way modern vehicles are the starting system is computer controlled . A relay is a switch controlled by the PCM - engine computer .
Nov 15, 2015 | 2008 Dodge Charger
Troy Bilt GTX 18 lawn mower engine won't continue running
ck. to make sure the wire to the ignition coil is hot. may need to replace the ignition switch.
May 24, 2013 | Garden
Car won't start
The daytime running light relay should not have anything to do with the engine.
If the engine cranks but does not start, you might want to check the ignition relay and EFI relay for power.
Do you have spark to the plugs ?
And what year is the car ?
Jan 28, 2013 | Ford Probe Cars & Trucks
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Have a '94 S-10 Blazer Tahoe 4X4 and it starts
My suspicion is a starter going bad. Sometimes when starters get old and worn they will start good when the engine is cold but not when the engine is warmed up. Did you perhaps notice that lately is seemed to drag when you tried starting, especially warm or it seemed to crank a little slower? I'd replace the starter. Hope this helps.
Aug 14, 2011 | 1994 Chevrolet S-10 Blazer
Truck dies but engine keeps running. battery or alternator?
You need an alternator....well unless your belt came off or got very loose. The truck continued to drive because the battery had enough juice left to run the ignition system, but after you shut it off there was no where near enough to turn the engine over or possibly even run the starter. The battery will have to be charged and a new alternator installed.
Hope this helps.
Apr 01, 2009 | 2003 Toyota Tacoma
1991 Isuzu PickupTruck will start but wont continue to run
check wires under dash & hood .check fueses & relayes sounds like u have a short !!!
Feb 15, 2009 | 1991 Isuzu Pickup
2005 F350 DIESEL,WAS RUNNING,SHUT IT SHUT OFF,WON,T START
first check the oil and see if it is full. the injectors are fired by oil pressure so check those things first.
Jan 31, 2009 | 2005 Ford F 350 Super Duty
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
