Question about GE WBSR3140DW Top Load Washer
I have a top load washer - GE 175D2750G310 that will fill, then clicks when begining to wash but does not spin and drain HELP
  • Monti Dec 08, 2012
    Theschematic mention somethng about doing a field service test but I wasn't able to make sense of the codes on the schematic.
    The solution was a clogged drain. Thanks
SOURCE: GE front load washer (clothes)
THANK YOU. for those of you with a screw driver, here are the photos on how to.
It takes a philips screw driver and 20 minutes. The white screws may not align perfectly but don't worry, just get them to go back in the hole(no harm done).
I'm going to admit it was my wife that found this fix, so now I give the step by step photos.
[IMG]http://i26.tinypic.com/23upff6.jpg[/IMG]
Small white screws (3 in total)
[IMG]http://i30.tinypic.com/69n9eh.jpg[/IMG]
cover "falls" off
[IMG]http://i29.tinypic.com/24erogl.jpg[/IMG]
Unscrew the lint trap (turn to the left)return when clean to hand tight
[IMG]http://i32.tinypic.com/9uralw.jpg[/IMG]
Bob's your uncle and a freebee for CMKX'rs.
Hub and wife team.
Posted on Apr 15, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile WPRE6100G Top Load Washer
The most likely cause of your problem is the lid switch.
Posted on Oct 27, 2008
SOURCE: GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Posted on Jan 19, 2009
  • 111 Answers
SOURCE: GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Posted on Jul 15, 2009
VtToolMan
  • 704 Answers
SOURCE: GE Profile Harmony Washer has loud squeak when filling
Based on your description, it sounds like the water inlet valve is making noise, since you hear a squeaking noise during the filling of the washer. If it sounds like a constant squeak or squealing noise, i'd say it's caused by either the water inlet valve not being pulled all the way open, or because the water supply shut off valve at the house end isn't open all the way. Try opening the water supply shut off valves all the way open, (check to see that they are).
What is interesting is that the squeaking comes back during the draining of the water. Is this while the tub is spinning or only at the very end of the cycle? Again, it could be the water inlet valve, since the washer will "spray" some fresh water into the washer during the final spin cycle to help remove any soap residue, etc.
The part ins't cheap at around $123.00 for this valve, so unless it's really annoying you to no end, I'd wait for the valve to stop working before getting the repair done, unless you want to do the repair yourself, which isn't difficult, with some basic tools and time.
If you wait and let this go until it fails, you'll notice the water in the tub might not fill all the way for the level set, or the valve will start getting even more as it gets worse.
Here's a drawing that shows your washer and the part I'm talking about.
pd_0026_363_wh13x10017?$pddetailsth$ Part #WH13X10017 $123.49 @ searspartsdirect.com
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WPGT9360E0PL&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00001&componentDescription=CONTROLS,%20BACKSPLASH%20&%20TOP%20PANEL&documentId=G0901083&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Posted on Aug 22, 2009
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Ge load size selector broken
You can buy this part, suggest you go online and purchase it. Contact this website: Appliance Parts Accessories Repair Help
May 19, 2017 | GE Profile WPRE6100G Top Load Washer
Washer fills with water and drains but will not agitate or spin out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 26, 2010 | GE Profile WPRE6100G Top Load Washer
GE top load Profile washer. Spin cycle not
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
GE adora WHDRE526EWW when started it begins to fill then stops filling and have to restart sometimes three to four times help!!!.
I wish I had a solution, I have the same issue. My WHDRE526EWW Top Load washer stops intermittently sometimes while filling up, sometimes while rinsing, sometimes while washing and sometimes while spinning. I just have to guess when it's going to stop and check on each load frequently to restart it when it stops. Sometimes I can't even get it to start spinning again and I will have to unplug it and plug it back in and then it will spin. Hope someone can help!
Jan 05, 2010 | General Electric WHDRE526EWW Top Load...
My GE Profile top load washer won't hold water
Your drain line is too low or has a blocked air gap. Take the drain line out of the drain. Hold it up high and turn the washer on to fill. If it fills and begins agitation,repair the drain line problem.
Sep 08, 2009 | GE Washing Machines
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
GE WBSR3140DW Top Load Washer Logo
310 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
