Question about Hanns.G Jc199d 19" Lcd Monitor - Black
How to change input to analog on JC199D
I want to switch the input to analog. When I go to the menu, set up menu, and down to input select it says "digital" next to it. Every time I highlight input select and press (2) it goes to a black screen for 5 seconds and then back to digital. How do I switch to analog to use the device that is plugged into the VGA port?
Pioneer plasma model PDP-507XA. how can I tune a TV channel?
The PDP-507XA only has an analog tuner. You will need a set-top box (digital to analog converter) to receive over-the-air signals in most places. For analog cable, you need to set the source to TV. Press the Select button, if needed (it's above and to the left of the arrow keys), to put the remote in TV mode. There is also an Input button on the TV. If the Channel Up/Down keys do not work, you need to reset the TV Press the Home Menu button. Navigate to the Setup menu (Up/Down arrows followed by Enter) and select Auto Installation. Enter your password for the TV; the default password is given in the manual on page 41. It's available from Pioneer here: docs.pioneer.eu/Manuals/PDP_507XA_ARE1430_manual . Set the Language (use the Up/Down arrows followed by Enter. Then use the Left/Right arrows to change the setting). Then set the Country. Press Start to begin a scan for channels. Alternatively, select Analogue TV Setup and enter the password. Then identify the correct receiving system. Manually enter the channels in the Search area. Set Store to Yes to save channels.
I hope this helps.
Feb 14, 2016 | Pioneer Televison & Video
How to get to menu then adjust it to antena?
First make sure that an antenna is connected the coaxial input on the TV and the input is set to TV. There is an Input button on the top of the TV and on the original remote. On the remote, the Input button is below and slightly to the right of the 0 button. On the top of the TV, the Input button is the one closest to the Power button. You can toggle through the Inputs by pressing the Input button several times or use the up/down arrows and then press the Input button to select the input. (TV should be the top item in the list.)
Next press the Menu button on the remote, above and to the right of the arrow keys. (There is no Menu button on the TV.) Use the left/right arrows to navigate to Setup. Next use the up/down arrows to select CH setup. Press Enter. If you've set a PIN, you'll need to enter it. Use the up/down arrows to select the line Air/Cable, if you need to change the source of your signal. Press Enter. Use the left/right arrows to select your source. Press Enter to save the setting. Press Menu to exit. Return to this CH setup menu and use the up/down arrows to select CH Search and press Enter. If you are using an OTA antenna, use the left/right arrows to select Start and press Enter. Wait for the search to be completed. For cable sources, you'd need to select from Analog Search Start or Digital and Analog Search Start. Press Cancel and then Enter to exit the search.
Crutchfield has the manual for the LC-32D62U available from the product page under the Details tab: http://www.crutchfield.com/S-mhRC3OB2Fi4/p_284LC32D62/Sharp-LC-32D62U.html . The direct link to the manual is http://d2stobyut4u5rx.cloudfront.net/ImageBank/v20080124174400/Manuals/284/284LC32D62.PDF . The Input button use is available on page 30 of the manual. The channel search steps are shown on page 23.
I hope this helps. Please note, if you have an replacement universal remote, you may need to try multiple codes for Sharp TVs to get the Menu button to work. If your replacement remote doesn't have a Menu button or none of the codes work, then you'll need a different remote.
Nov 07, 2015 | Sharp Aquos Lc32d62u 32-inch 1080p Lcd...
Hanns-g JC199d monitor displays 2 messages periodically
install an AGP card into an AGP slot because internal display card does not support high resolution because of insufficient memory . use 8X AGP card for better result . then you can see high resolution ,3D games ,and movies .
Apr 17, 2010 | Hannspree HANNSĀ·G JC199DP LCD Monitor 19...
No sound when connecting optical cable from set top box to #4 optical input for cable tv on rear. The cable only works from the front input or the dvd input on the rear but that limits my sound fields. I...
Make sure your "Input Select" "Audio" portion of the main menu is set to "Auto" you may have it in analog thus only allowing audio from the front analog input. Also check your digital input select option as well. you may have it assigned to another source input. Go into the main menu of the receiver and you will find all the settings. Hope this helps. If you still have issues, post a comment and I can help you troubleshoot further.
Feb 26, 2010 | Yamaha HTR-5760 Receiver
May be a dumb question, but how do I switch singal input on this monitor.
The right side top button is Menu is has a letter M on it. From the menu display select the seventh option using the up and down buttons.
Select the「Input Setting」option to change between the analog (D-Sub) or Digital (DVI) source. Enter the option and select Analog or Digital.
http://america.hannsg.net/filectrl/HW191_UM_EN.pdf
Oct 13, 2009 | Hannspree HW191D LCD Monitor
Wrong region.on screenhelp please
try to make it region free by using the steps below
1 Press power on
2 Press set-up
3 Select preferences menu
4 Press play
5 Input 251131
6 Press "Left" then "Down" button
Should show region code
7 Select region
8 Press set-up to confirm and exit.
or
Now on the remote control
3 Press set-up
4 Select preferences menu
5 Press play
6 Input 251131
7 Press "Left" then "Down" button
Should show region code menu
8 Select region free by hitting the 10/0 button, this will change the region to region free (ie 0)
9 Press set-up to confirm and exit.
or
1 Before powering on, open the lids, remove any media and leave it open so you can actually see the compartment where you place a disc.(this is how you get access to the preferences menu)
2 switch on unit from the side of the drive
3 Press set-up
5 Press play
6 Input 251131
Nov 27, 2008 | Mintek MDP-1770 Portable DVD Player
Monitor switchs between digital and analog
I had a similar problem, the monitor was going blank once in a while (since I don't have a VGA input), so I switched the Auto Source feature to "Manual" and so far it's working fine for the past 2 days, if I run into the problem again I'll update this message.
On the side panel of your monitor, press the top button to access the menu, scroll down to the setup menu (by pressing the 3rd button down on the panel), press the 4th button down to enter the setup menu, scroll down to "Auto Source", use the 4th button to select, "Auto" & "Manual" are your choices.. press the 2nd button down to select "Manual" then the top button to exit the menu(s).
This monitor is set up to be able to do multi display with the software included. Utilizing both Digital and Analog signals. I'm not using this feature so I'm not sure how switching the Auto Source off will affect the performance of this feature.
Aug 18, 2008 | Computers & Internet
PLV-Z2 AV System Menu locked on 1080i
If I understand your description correctly, when comparing it with my Z2, this is a function of the input type. If you have the input set to DVI and ANY digital source connected, the projector selects the mode that it is receiving and does not allow you to modify it. The options on this menu are only available when using an analog input. Try switching to any of the analog inputs and see if the option doesn't re-appear. It seemed strange to me too at first, but it makes sense because the digital input does not require "fine tuning" to convert it from analog to digital because it is already digital and therefore the signal itself skips this conversion step and the menu that goes with it.
Feb 25, 2008 | Sanyo PLV-Z2 Multimedia Projector
No analog input option on my camcorder menu!!!!!
analog input are those using RCA plug or mini headphone plug, so if you are making no connections to this ports, maybe its off. Or an option to switch between digital and analog and selecting digital input would turn off analog input.
Feb 06, 2008 | JVC Everio GZ-MG155 Camcorder
Switch from Analog to Digital
To move to Digital (you need to have a DVI cable for this)
I'm using the monitor now and typing these instructions Mine is a HW191D Silver:
Button Layout:
(1) Menu
(2) Auto Adjust (does nothing when in digital mode)
(3) Move up in menus
(4) Move down in menus
(5) Power
Press the Top (1) button to display the OSD Main Menu
The Press the button Next to the Bottom (4) twice (Input Setting should be highlighted)
Press the Top button (1) once to allow you to select between Analog and Digital (use the button next to the bottom (4) to select between the two)
Press the Top button (1) and it will change to the input that you selected.
If you selected Digital and you don't have a DVI cable connected, the display will go black and then return to Analog (VGA)
(1)(4)(4)(1)(4)(1)
I hope that helps
toypaj
Mar 18, 2007 | Matrix HANNSFREE 19 Analog and Digital...
Hanns.G Jc199d 19" Lcd Monitor - Black Logo
60 people viewed this question
Top Hanns.G Computers & Internet Experts
David Payne
David Payne
Are you a Hanns.G Computer and Internet Expert? Answer questions, earn points and help others
