Question about Dodge Vehicle Parts & Accessories
1998 dodge dakota. takes to long too warm up. already changed thermostat
  • 22 Answers
I'd suspect the thermostat again. But I think you radiator core is partially blocked and you had overheating, so the need for a new thermostat.
It doesn't help to replace the thermostat alone, most modern thermostats have a composite metal alloy retaining the spring, so when the radiator overheats the alloy fuses over and releases the spring, completely opening the flow of cooling liquid.
One of the symptoms of radiator blockage may be a non-operating interior heater (it's also clogged).
One way to test the radiator for blockage, is to start the truck cool, let's say first thing in the morning, and carefully put your hand on the radiator fins, moving along the surface, as the motor starts heating. If you detect a mix of warm and cool zones, your radiator is clogged.
I'd recommend you first change ALL of your hoses (ALL means ALL of them, including heater, A/C, etc), then do a cooling system flush, then drain completely the system and try to force water to clean debris in the system, then blow compressed air to flush the remaining liquids.
Now, change the main radiator and the heater radiator, install a new thermostat and fill it with NEW (check the dates) liquid coolant.
If you're doing your own mix, use only distilled water; even if the system is a closed circuit, minerals in the few gallons or quarts of water can interact with aluminum parts in you motor.
Since you'll be removing the radiator, I'd check also the water pump seals, it may be worth to change them, even if they are not leaking; water pump seals and gaskets are a common problem with Dakotas and Durangos.
Hope this helps.
Posted on Jun 02, 2014
Starts and shuts off when I stop at stop sign or light.
dodge dakota idling and dying - CarGurus
www.cargurus.com > Questions > Dodge > Dakota
CarGurusApr 12, 2011 - dodge dakota idling and dying - My dakota will start then idle down and die. ... I have a 1992 dodge dakota that dies on me at stop signs and when I take my foot off the gas pedal. ... Had the same problem with my 98 Dakota.
Dodge Ram 1500 Questions - 1998 1500 5.2 Shuts Off ...
www.cargurus.com > Questions > Dodge > Ram 1500
CarGurusAug 29, 2011 - 1998 1500 5.2 Shuts Off Randomly - does anyone have an answer to the mysterious shutting ... 1998 1500 5.2 that shuts off randomly and if i wait a few seconds to minutes it will start again. ... does it do it when coming to a stop or when taking off from a stop or shifting from drive to .... Used Dodge Dakota".
Truck Shuts Off - 1998 Dodge Dakota - RepairPal
repairpal.com > Questions > Dodge > Dakota > 1998 Dodge Dakota
I have a 91 dodge dakota truck with a 318 motor, 249,000 miles, it will start up thenshut right off when I take my foot off the gas pedal, I had a tune up a month ...
2000 Dodge Dakota idle then dying problem FIXED - YouTube
? 4:05
https://www.youtube.com/watch?v=XRVQEdnei34
Mar 26, 2014 - Uploaded by AoDMADPenny
It would rev up then back down to about 200 rpm then just shut off. ... My Dakota dies during idling right after i start it up and then it wont start back up again. .... 1998 Dodge Durango No Start or No Bus or Randomly Stalls ...
Jan 06, 2016 | 1998 Dodge Dakota
Fixya review
could be thermostat or egr valve car didnt warm up correctly try taking off battery terminal for a minute then try again more info would help
Feb 27, 2014 | Cars & Trucks
Put on new water punp and theromstat still take long tiem to warm up dodge dakota 1949 3.9 how can i fix this
Confirm the Thermostat you replaced it with. Same heat rating? Also, when it finally does warm up, does it stay within the normal operating range? If it's "overheating" then you still have a flow/blockage issue (heater core, hose, engine block etc)..
Mar 12, 2011 | 1994 Dodge Dakota Club Cab
Air coming out of vents is warm not hot,
you may have a stuck open thermostat or low coolant.
Feb 04, 2011 | 1998 Dodge Dakota
1993 dodge dakota 4X4, 185.000miles LX Model 3.9 , runs great had since feb 1993. Problem, very little heat, thermostat has been changed, coolant is good. Takes a very long time to obtain any heat and...
If the vehicle reaches operating temp ( where you normally have good heat ), and the heat is still slack I would suspect your heater core is partially blocked and a backflush would be the place to start. If your vehicle isn't reaching operating temps possibly a thermostat failure, or overcooling issue ( this is why you will see cars / trucks partially blocking radiator flow by means of a cover that's snapped on or some other means)
Jan 21, 2011 | 1993 Dodge Dakota
1998 Dodge Dakota - fan is blowing but barely any heat comes out.
Change the thermostat, if it is more than 5 years old
Need 3 blower speeds or Blower Resister is rusted away
Dec 14, 2010 | 1998 Dodge Dakota
When heater on only warm air comes out of ducts
Thermostat,sticking open too far,you notice it, now it
is colder outside
Nov 26, 2010 | 1998 Dodge Dakota
1999 dodge dakota blows cold air at idle but heat warms up when revved. would like a solution to this heater problem. I live in alaska and need the heat to function properly. already flushed the heater...
Sounds as if the engine is not building up temp due to cooling system working. If engine temp gage is reading low try covering 1/3 of radiator with a piece of cardboard "Bumper side" to reduce the cooling effect.. just watch temp and out side temps if warming up outside or heavy driving remove the blocking to allow full cooling
Jan 22, 2010 | 1999 Dodge Dakota
Where is the thermostat located at on a 1998 Dodge Dakota? And the heater is not heating the compartment.
Follow the upper radiator hose from the radiator to the motor. There should be two bolts holding the hose-to-block outlet in place. The thermostat is directly below this in the intake manifold.
Before you take it all apart, check your radiator coolant level. If it's really low, there will be no flow of warm coolant to the heater core and you wont' be getting heat in the cab. Fill to the recommended level and recheck your heater...
Nov 22, 2009 | 1998 Dodge Dakota
My 99 dodge dakota wont heat new thermostat motor
You have a bad heater valve, operated by vaccuum or cable its on the hot water line on its way to the heater core.
Feb 20, 2009 | 1997 Dodge Dakota
Vehicle Parts & Accessories Logo
64 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
