Question about HP xw4400 Workstation PC Desktop
HP xw 4400 will not recognize my hard drive when trying to install OS Windows XP Prof.
  • 242 Answers
Windows XP had a hard time recognizing hard drives larger than 127 GB. The best solution is to install Windows XP with service pack 2 or 3 already slipstreamed. Otherwise, you are going to have to partition your hard drive with at least 1 partition of 127 GB or smaller.
Posted on Dec 08, 2012
  • 3940 Answers
SOURCE: REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
Posted on May 19, 2008
  • 44 Answers
SOURCE: i have just purchased a
just do this.go to c-mos setup by pressing F2 select SATA operations then change ahci to ATA.
SAVE &REBOOT
Posted on Aug 12, 2008
bharrie
  • 158 Answers
SOURCE: Hp compaq presario v3000 is not loding the OS, show an error
  • as you boot the computer, start tapping the F8 keys
  • From the boot menu, select Safe Mode
If this seems to work, you can try restoring the computer to an earlier point from Start > All Programs > Accessories > System Tools > System Restore.
If Safe Mode also fails to load, you would have to check your disk for errors or you may have to install XP all over again.
Please get back, if you need any further help.
Posted on Jan 09, 2009
jomabug76
  • 1148 Answers
SOURCE: unable to load audio drivers, OS Windows XP SP-3
DOWNLOAD NEW DRIVERS FOR YOUR SOUND CARD
Posted on May 15, 2009
SOURCE: HP Workstation xw8200
Server 2008 is not detecting your drives, because it does not have drives for what ever hard drive controller you are using. You will need to determine which controller your drives are attached to and load the appropriate driver during setup. I believe this system has built in SCSI and SATA controller and often shipped with add - in storage cards. Our came with a promise sata raid controller.
Posted on Jul 22, 2009
Not recognizing hard disc drive for windows xp reinstall .
You aren't using the correct install disk . The generic XP install disk can't recognize a SATA disk.You will have to load the appropriate driver during install. Here it is ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32492.exe
Or you could create a custom install disk  as explained here
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
May 13, 2010 | HP Compaq Presario C304NR Notebook
Hello'I' gt a compaq d330 ut desktop Pc to arrange
If you format the hard drive NTFS format you should be able to install Windows XP. If the computer is old, the hardware may not work with Windows XP. Any computer built in last 8-9 years should work with Windows XP.
Nov 08, 2009 | HP Compaq Business Desktop d330
XP Prof installation can not find the Hard disk drive
hi,this is very simple problem.
before installing XP press F2 (go in system setup)
and there look for every option,there will be an option for hard disk.on that option select "SATA"
AND THEN PRESS F10(to save your choice)
after that exit and insert XP cd,window will start installing.
cheers
Jul 16, 2009 | Computers & Internet
Im using hp dv6700t laptop,i want to install xp on my laptop
Your laptop has a SATA hard drive and windows XP doesn't recognize those drives cause the operating system came out before those drive were made.
Follow these steps I found thru google to get windows xp sp3 to recognize your drive:
http://en.kioskea.net/forum/affich-39282-xp-can-t-recognize-hard-drive-for-os-install
You'll have to use a program to do this but people explain how to do it on that page plus the program is free.
Jun 25, 2009 | HP Pavilion dv6000t 15.4" Notebook Laptop...
HOW TO INSTALL XP IN VISTA OS OF LAPTOP HP PAVILIION
Hi there.
The only way you can install XP on a Vista machine is to install "virtual XP" onto Vista using Virtual PC 2007.
Here is a site that will take you through the procedure step-by-step and gives links to download Virtual PC and install it onto the machine.
Please be aware that some drivers may not work whilst using XP when you have it installed.
http://lifehacker.com/software/windows/geek-to-live--run-windows-xp-inside-vista-with-virtual-pc-238071.php
Have fun, good luck and thanks for using FixYa!!
Mar 23, 2009 | HP Pavilion DV6700T Notebook
Sound driver of winxp prof. for hp pavilion
Try this Link
It's for Vista but it may work.
Or this Link
It's older but dedicated for Win XP
Mar 07, 2009 | HP Pavilion dv2500t Notebook
Hp pavillion dv6000 laptop drivers for microsoft windows XP prof.
try to download belarc advisor software. Run this in your vista OS and send it to me so I can check your hardware specs. This is the only way to avoid problems in the future or before you start the formatting.
Dec 01, 2008 | HP Pavilion dv6000z Notebook
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
Lost Acer eRecovery password on Acer Travelmate 2350
i bought a acer aspire 3six20 from my classmate but i forgot tto backup the erecovery.. when i instaler a new xp the logo in6b5df8b.jpg
Jan 25, 2008 | Acer TravelMate 2300 Notebook
HP xw4400 Workstation PC Desktop Logo
286 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
