I have samsung ln40b540p8f tv. Sudenly image is going off and on and this for every deveic conected to the tv: every 30 seconds image goes off than on and after 2 or 3 tmes like this no more image. Somebody ca help?
4 Suggested Answers
SOURCE: sony wega 60 in turns on and off by its self
Same problem here also and its getting worst each day.
Posted on Nov 20, 2007
  • 50 Answers
SOURCE: Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Posted on Aug 07, 2009
ginko
  • 19396 Answers
SOURCE: TV will only stay on 30 seconds
It looks like a bad PSU board.
Try leaving the TV unplugged overnight, that can fix some problem related to accumulation of charges on Power Supply capacitors.
On restart start the unit without connecting to receiver box, eventually use a DVD to test it.
If that does not work, then the TV is faulty and must be repaired. In that case better ringing the number listed on the owner manual.
Posted on Aug 16, 2009
Testimonial: "Your solution is probably correct and I will let you know as soon as I try it. "
Samsung LCD 40 tv model LN40B540P8F serial AUC13CES602650E
It is likely that your Samsung TV has a power supply problem.
Feb 20, 2014 | Televison & Video
I have a 50 in samsung plasma tv and it sudenly had a 2in wide black and colourrd line from top to bottom appear ? any idears
try and bend the set slightly. IF line goes away suspect ribbon cable connector from x driver boards to panel. The connectors brake away from panel and thus a replacement panel must be installed.
Feb 18, 2011 | Samsung 50 in. Plasma TV
From 1 to 10 ten been the best how good are this tv 55PP9363H/17 1 TOSHIBA 6211M15 1 SONY KFSOWE620 1 MAXENT MX26X3 1 SAMSUNG LN32BS40P8D 1 MAXENT MX26X3 1 MAXENT MX42XM11 1 SONY KDLS2VLISO...
The Samsung LN40B540P8F I would rate a 9. Only God is 10.
All the DLP sets, you can throw out
All the Older Projection sets you can throw out
I would take the rest for scrap parts.
I hope this is helpful.
Dec 18, 2010 | Philips Magnavox 51MP392H Rear Projection...
Freezes turns white then turns off then back on
IF YOUR IMAGE IS ALL WHITE YOUR LOGIC BOARD IS DEFECT BUT IM SAD TO SAY DO NOT REPLACE THE LOGIC IT WILL ONLY TEMPORARLY SOLVE THE PROBLEM THE PANEL IS OVERLOADING THE LOGIC BOARD PANEL IS BAD
Apr 24, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I have just been given a Samsung sp42w4hb back projector TV that has a problem,after about 4 power cuts in the area the TV went off and only the standby light comes on,it stays on for about 10/15 seconds...
check to see if you have a loose conection at the relay or at the power source a lot of times the relay goes bad and you can solder a neew one in get a service manual to locate relay and parts
Jan 21, 2009 | Samsung Televison & Video
Samsung rts-he10 sound
shown, from the DVD the if you are trying to the and image from the DVD to the TV goes conected on the output, and to the TV In the input. the color dont make a diference as long as what ever color you have is on the same output - input meaning
R Output - R Input
L Output - L Input
Jan 08, 2009 | Televison & Video
Video warps on edges then cuts out to black, then fades back in
Please dont rate me if could not fix your problem. Check the tv lamp. If doest work well, replace it. Thank you..
Nov 29, 2008 | Samsung TXM3096WHF 30" TV
Flickering image
I have a vcr and dvr combination emerson tv a 27 inch and sometimes while playing it will flicker and these horzion lines come in while a program is runing, and then the sound goes way down then comes back up to normal.
can you give me a answer?
Is it my picture tube it is about to go out?
It is close to five years old
Feb 23, 2008 | Emerson EWF2703 27" TV
Televison & Video Logo
318 people viewed this question
Top Televison & Video Experts
Electro Med Services...
