Question about Desa International Heating & Cooling
I have a gas system model# RFN28TA that is natural gas.
Can i switch it to propane.
Yes but you must change the valve from natural gas to a propane gas valve, that's a little bolt shaped metal piece that has a hole in it to restrict the flow of gas. You should probably should take it to a professional
Posted on Jan 12, 2009
Can I convert from natural gas to propane
Yes... you just need a retrofit kit.
Jan 26, 2016 | Heating & Cooling
I had a natural gas furnace installed in place of a propane gas furnace. will this cause my rollout switch to trip constantly. my fuel source is propane. gas valve on furnace wasn't change to propane
If it has a position for natural gas/propane then it needs to be changed to the position that the gas source is either propane or natural gas..
Nov 22, 2015 | Heating & Cooling
Can you convert the tankless water heater model # RL94in from natural gas to propane?
Contact Rinna
Some water heaters allows changeover by installing new chipboard or changing dip switches... some do not.
Propane burns much hotter with higher pressure than natural gas
Gene
Water Heater Timers Save Money
Feb 14, 2015 | Rinnai RL94i Tankless Water Heater
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
I am trying to switch a natural gas deep fryer to propane and cannot fimd the correct part
Hi there.
You can visit http://www.imperialrange.com , you can verify there the correct parts list for the model of your fryer for the conversion from natural to propane and you will be able to search there the nearest authorized parts and service provider in your area.
You will be needing burner orifice for propane, pilot orifice for propane (if available, if not, the whole pilot assembly), Gas valve spring for propane (if available, if not, the whole gas valve for propane).
Regards.
Aug 03, 2011 | Imperial IFS40 Deep Fryer
Can i switch a model RN30 from natural gas to propane?
Only the portable heaters that are manufactured to be used on dual fuel (nat gas/propane) can switch from one to another. If they are made for 1 type of gas only, they are not field serviceable and cannot be converted. Douglas
Sep 30, 2010 | Reddy Heater-30-55,000 BTU Variable
How do u switch it from natural gas to propane
You can purchase a set of propane gas orifices to swap out for the natural gas orifices that your unit has presently.
Contact a local appliance parts supplier and ask for the propane gas orifices for your specific model.
If you swap them out, you will be good to go.
May 13, 2010 | Magic Chef 31000 Gas Kitchen Range
Switched from natural gas to propane now oven flames up sides how do I fix? Model#362.75571691
Propane and natural gas are two different fuels and require adjustments to the appliances to which theye are connected. Typically, when converting to propane from natural gas, a pressure regulator and a change in gas jets are required. This is because propane has a different heating value (hotter) and behaves differently.
Also, propane doesn't burn as cleanly as natural gas so after you have made the hardware changes, if you start to smell something in the kitchen, you may need to crack a window slightly to provide for better venting.
Please be careful
Jan 01, 2010 | Kenmore Kitchen Ranges
SWITCH FROM NATURAL GAS TO PROPANE GAS MAYTAG MGR 5755 ADQ LOKING FOR GUIDE AND DESCRIBE ALL PARTS, NEEDED TO SWITCH FROM NATURAL GAS TO PROPANE GAS . PLEASE THANK YOU
Hello. Contact your propane provider and they will get you the conversion kit for your maytag model. In fact, they will send a technician to your home for free to make the conversion for you.
If you want to do it yourself go to any appliance store that handles maytag and get the conversion kit. Then remove the orifices that are currently in the stove and replace them. Regards, Joe
PS please rate my answer.
Dec 17, 2009 | Maytag MGR5755QD CleanDesign Gas Kitchen...
I received a Gas heating system from my dad and would like to know if I can switch it from Natural to propane gas. my model # RFN28TA.
Most furnaces come from the factory set for natural gas. If you contact the manufacturer to find the local distributor for that particular unit . you should be able to order a propane conversion kit. The kits are very easy for a trained heating guy to convert. A good handy man should be cable to do this changeover. BUT the manometer that is needed to properly calibrate the gas valve is not worth the purchase price for one application. I recommend that you use a trained heating guy.
Jan 12, 2009 | Heating & Cooling
Heating & Cooling Logo
183 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
