I received a Gas heating system from my dad and would like to know if I can switch it from Natural to propane gas. my model # RFN28TA.
    Novelist:
  • 189 Answers
Most furnaces come from the factory set for natural gas. If you contact the manufacturer to find the local distributor for that particular unit . you should be able to order a propane conversion kit. The kits are very easy for a trained heating guy to convert. A good handy man should be cable to do this changeover. BUT the manometer that is needed to properly calibrate the gas valve is not worth the purchase price for one application. I recommend that you use a trained heating guy.
Posted on Mar 08, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
How to change from natural gas to propane
Hi Rodney.
the main change from natural gas to propane is that propane has a bit higher energy content than natural gas, so you may heat things a bit faster. The particulars will depend on your specific make and model of range, but, for instance, with my KitchenAid gas range, the primary difference was getting a slightly different connection orifice made to give proper propane flow and pressure. The install kit may also have listings for necessary delivery pressure ranges from you propane source. If the range is built in, it might be a bit of a pain to get at the gas connections, and it's best done by a professional who will know the proper fittings, seals, and pressure tests to do to make sure you aren't leaking gas all over your kitchen.
That said, it's likely not a particularly big deal.
Good Luck!
D
Nov 24, 2015 | Kitchen Ranges
I had a natural gas furnace installed in place of a propane gas furnace. will this cause my rollout switch to trip constantly. my fuel source is propane. gas valve on furnace wasn't change to propane
If it has a position for natural gas/propane then it needs to be changed to the position that the gas source is either propane or natural gas..
Nov 22, 2015 | Heating & Cooling
Converion kit to natural gas.
I don't believe Weber makes a gas conversion kit for your model grill. I say this, because your model grill comes two ways, Natural Gas or Propane. This indicates to me, that there's more than just changing the burner orifices involved.
I can tell you this ... If you could convert it to Natural Gas, you would soon discover that the grill doesn't preheat as fast as with propane. Nor, will it maintain heat as well as propane, in an outdoor environment. Propane burns cleaner and hotter than Natural Gas in an outdoor environment.
Sure, it may seem like a hassle to refill and change the tank, but I can assure you, you won't be satisfied with it's performance.
Feb 03, 2011 | Weber Spirit? E-310 Propane Grill
How do u switch it from natural gas to propane
You can purchase a set of propane gas orifices to swap out for the natural gas orifices that your unit has presently.
Contact a local appliance parts supplier and ask for the propane gas orifices for your specific model.
If you swap them out, you will be good to go.
May 13, 2010 | Magic Chef 31000 Gas Kitchen Range
Switched from natural gas to propane now oven flames up sides how do I fix? Model#362.75571691
Propane and natural gas are two different fuels and require adjustments to the appliances to which theye are connected. Typically, when converting to propane from natural gas, a pressure regulator and a change in gas jets are required. This is because propane has a different heating value (hotter) and behaves differently.
Also, propane doesn't burn as cleanly as natural gas so after you have made the hardware changes, if you start to smell something in the kitchen, you may need to crack a window slightly to provide for better venting.
Please be careful
Jan 01, 2010 | Kenmore Kitchen Ranges
Trouble with waterheater
DO NOT USE THIS HEATER UNTIL IT HAS BEEN CHECKED OUT BY A PROFESSIONAL!
Most all gas appliances can use propane or natural gas, but they ship from the factory with orifices for one or the other.
Propane is rated at 11 iwg, natural gas at 7 iwg (where iwg=inches water gauge. 27 iwg=1 psig) (it takes a different regulator spring to handle this small difference in pressure.
A propane orifice will be smaller than a natural gas orifice.
The store that you bought the water heater should know what they sold you, and know if they have a kit to convert the regulator and orifices.
Jan 15, 2009 | Reddy Heater RLP100 Portable Forced Air...
I moved and after hooking up my gas dryer to gas tank it will not heat up....
were you on propane b4 the move or natural gas? A natural gas dryer will not run on propane nor a propane one run on natural gas
Jan 14, 2009 | Kenmore 73932 Gas Dryer
I have a gas system model# RFN28TA that is natural gas.
Yes but you must change the valve from natural gas to a propane gas valve, that's a little bolt shaped metal piece that has a hole in it to restrict the flow of gas. You should probably should take it to a professional
Jan 12, 2009 | Desa International Heating & Cooling
Physical difference between natural & propane orfice
Merry Lynn, there will be no physical differences between Natural Gas heaters and Propane Gas heaters. Check the model number of the unit, it may have a N or P or LP printed at the end of it to distinguish which gas it uses. The plate that is attached to the heater should indicate the type of gas it uses.
DO NOT try to convert this heater to another gas.
Oct 16, 2007 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
