Question about Dryers
Hotpoint tumble dryer tcm580p drum not turning
SOURCE: free manual
Hi Mark,
Try putting this into the address bar of your browser
http://laundry.manualsonline.com/manuals/mfg/hotpoint/aquarius_aquarius.html?s=fpw
Posted on Mar 22, 2009
TAGTEL
  • 16 Answers
SOURCE: TUMBLE DRYER DOES NOT GET HOT
Hi, - The first thing to do is UNPLUG THE DRYER! Then remove the heater cover situated on the back panel. It is the curvey shaped panel.
Remove all the screws and the panel may be slightly stuck - just prise it off.
Next - there are 2 small screws holding the heater and thermostats assy onto the back panel. - Remove these to free the assy from the back panel. Be careful not to touch the elements as they break easily.
The problem is probably the Thermostats.
The one on the left is the Overheat Thermostat - You will notice a small hole in the centre of the thermostat. Take a Pin and push it firmly into the hole and you may hear the Stat "click". That has re-set the stat.
Re-assemble the Dryer being careful with the elements.
Now - Why has it tripped? If it has overheated it is because of one or all of the following.
1. The Condenser unit is getting blocked - Remove and clean under running water like a hosepipe or tap.
2. The door filter is not being cleaned
3. Sometimes opening the door to check if the clothes are dry and then not allowing the dryer to cool down can cause the problem. Always allow it to go through the cool down process.
Hope this helps. The Heater and the Thermostats are available as Spares - Terry
Posted on Mar 15, 2008
barkencoa
  • 3463 Answers
SOURCE: tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
barkencoa
  • 3463 Answers
SOURCE: tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Posted on Feb 01, 2010
Testimonial: "Straight-Forward answers, quick - ace!"
barkencoa
  • 3463 Answers
SOURCE: How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Posted on Mar 23, 2010
Drum not turning
Hotpoint tumble dryer not turning? How to replace a hotpoint tumble dryer belt
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Nov 12, 2013 | Hotpoint TVF770 Tumble Dryer
Not filling water tray,condensating all around dryer
hi is condensor box nice and clean in bottom
Feb 15, 2013 | Hotpoint Dryers
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
How to replace drum belt
Nov 04, 2012 | Hotpoint TVF770 Tumble Dryer
Mar 23, 2010 | Hotpoint Dryers
Tumble dryer drum won't turn hotpoint vtd00
Thankyou.
Jan 31, 2010 | Hotpoint Dryers
Jul 06, 2009 | Dryers
Hotpoint gas dryer will not tumble
Try checking the belt that wrap's around the drum, sound's like it might be broken.
Apr 06, 2009 | Hotpoint NVL333GY Gas Dryer
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
I need the procedures on how to change the drive belt on my Hotpoint VTD00G Tumble dryer. I've opened the top & front covers, placed the belt round the drum but I couldn't stretch the belt over the...
Apr 06, 2008 | Dryers
Dryers Logo
95 people viewed this question
Top Dryers Experts
