Ecu bord in tata407 reparing - Computers & Internet
Rear brake light
YOU HAVE TO REPARE THE BRAKE WIRE OR U HAVE TO REPARE LIVER(COMMONLY LIVER GET CANCEL) SO REPARE IT THEN YOUR REAR LIGHT START WORKING....
PLS RATE ME
Jan 03, 2014 | 2011 TVS Apache RTR 160
How do i repare is fuse in side bord
u cannot repair. If fuse is gone check diodes in the poer supply. check fuser unit also.
Oct 29, 2013 | Brother MFC-8220 Fax
Keyboard not working good
i cant spel good but deall with it
okay thers a few thing that can be wong with it. i can only say thisd. if it derty you should depending on how much dert on it you a cleen it with a spray bottle or take the keys of it and cleen it out then replace the keys back on it.... mack sher you rember ther order. prob 2 is bad cord. youll need a broken key bord and a sodering eye-ern. you the tack apart you bord and then photo grafe the bare cord you should se som clored cors that go into you bord chip photo that. ockay remove bothe the cords frome you two key bords then replace that cord to you bord ther have fun......
May 24, 2012 | Gateway M405 Series Laptop Charger...
My air bag light is on
You need to access the Airbag ECU (Electronic Control Unit) using VAG or similar diagnostic equipment connected to the data link connector of the car, in order to pull out all DTC (Diagnostic Trouble Codes) memored. Then you will be full informed about bad components, and you will be able to repair & replace bad pieces. After reparation it's necessary to erase all faults from Airbag ECU & reset it. The Airbag ECU warning light can only be turned OFF using suitable diagnostic equipment! Disconnecting the battery will not turn OFF the Airbag ECU warning light!
Good Luck!
May 29, 2011 | 1999 Volkswagen Passat
I want to my bioes reset.how?
take off the battery and turn on computer then turn off , back the battery to its place again and turn your computer on , it will be reset
if you see that is helpful please don't forget to vote me
best regards
Apr 25, 2011 | Intel D945GCLF Motherboard
Truck turns over but does not fire
I had the exact same problem. It turned out to be the ECU (engine control unit) On this model the capacitors on the ECU leak and ruin the Bord. Therefor the truck will not start or have problems. The ECU its located on the right side where the passenger places there feet. Its is a yellow/gold colored box.
Please let me know if this helped,
Nick
Aug 23, 2010 | 1991 Mitsubishi Mighty Max
Usb not reconnigation
if usb is not recoginize click on my computer then hardwere then click device manager. look usb softwere is stall or not ? if stall . keep a other usb card in pci slot in computre(mother borD) iblemt means your bord usb system may be damage. in our jeneral practis we face 945 gcr bord are damage many .time. so i like to say if driver not shown your bord usb hardwere system may be damage.
Jul 14, 2009 | Intel D945GCCR Motherboard
My Washing Machine 13 month old, was repared 1
Likely the ECU is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
Computer not powering on
There are various reasons a computer may not power on ....... there may b a problem with the power supply , there cud b a problem with the mother board .....
Try
open the cabinet ...... remove the main power cord connected to the mother board wait for a few seconds and connect back ...check
Oct 18, 2008 | Sony Ericsson K800i Cellular Phone
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
