HP Pavillion screen goes black when inactive for short time. Even when I fixed all of the power settings to never shut off or go into sleep mode. If I don't use it for 30 seconds then the screen goes black. If I press a button it comes right back on but very annoying it won't stay on for longer when it is inactive!
  • Computers & ... Master
  • 27,725 Answers
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Posted on Dec 08, 2012
narchoor
  • 22 Answers
SOURCE: Screen Blackout
u must be having problem in output display driver,,,try replacing it
Posted on Nov 17, 2007
  • 131 Answers
SOURCE: hp pavillion trying to boot from dos mode
my pc is writting Disk boot failure, insert seystem disk and press enter. pls help.
Posted on Apr 30, 2008
  • 1602 Answers
SOURCE: wont come outof hibernation goes to a black screen even upon rest
RESTART IN SAFE MODE.
OR
REBOOT SYSTEM, BEFORE IT BOOTS PRESS
F6 UNTIL YOU HEAR THE BEEPING NOISE, THAN STOP AND SELECT SAFE MODE
THAN CONTROL PANEL AND SELECT POWER OPTIONS
POWER BUTTON OPTIONS
Posted on Mar 14, 2009
SOURCE: not turning back on after sleep mode
I had the same problem when I first bought my Acer Aspire One a few weeks ago. I searched the web for answers, but it didn't really seem like anyone had a solution. However, one guy on a forum or website said something that gave me an idea - he said something like: What's the problem? Just open it up, hit the power button, type your password, and it wakes up.
Well, that didn't seem helpful to me at the time that I read it, but after thinking about it, I had a hunch. I had not set up my netbook to have a password (yet). So I did. And it's been waking up from sleep mode like it should ever since!!!
Hopefully, if you're reading this, setting a password will work for you, too. If you don't know how to set a password, here goes... Start...Control Panel...User Accounts...Change an Account...[Pick your name.account]...then the option to create a password should come up. Let us know if this works for you!
Posted on Mar 15, 2009
Morikvendi
  • 56 Answers
SOURCE: HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Posted on Jun 01, 2009
Laptop screen goes off and then to sleep mode
go into your control panel and under power saving turn off the sleep mode settings also check power saving sleep mode settings in bios by pressing f2 at boot also check battery options in security settings hope this helps and yes hp techs are just high paid plumbers reading memos from screens so there not usually much help lol
Mar 01, 2013 | HP Pavilion Computers & Internet
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
I have old pc that worked for too long but after i bought new screen ( HP L1950 ) every time it says montior is going to sleep and some time it freezes forever and some time it says no signal but after i...
* check com cable all thru the video card socket,also check you video graphic card pci if its inserted properly,try to clean it first.
* might your pc is in Hibernate or Sleep mode
A power management mode that conserves power by powering down the system. In hibernate mode the current state of the system is saved to the hard drive, and the system will power down. When a user turns the system power back on, the saved information is read from the hard disk, restoring the last used settings. Hibernate mode is similar to sleep mode, however in sleep mode the power cannot be shut off.
go to control panel > power management and change or default the settings you wish.
Jun 08, 2011 | Computers & Internet
Screen goes black. Put it in sleep mode. Then hit the start and it comes back on even with powercord in..what can fix it?
this could be probably due to static charges or corrupt bios settings.
Turn off the PC, disconnect the AC Adapter and remove the battery. Now press and hold the power button for 45 seconds.
Now download and install the latest BIOS update available for your notebook from manufacturer's website. If issue persists, reinstall the display drivers.
I hope this will help to resolve the issue.
May 20, 2010 | HP Compaq Business nc8000 Notebook
Computer goes to sleep before it even starts up
Hi there, it appears as though the Power Options are set too short a time and the PC is going into sleep mode. Go to Start menu/Control Panel and look for Power options. Set them all to "never" This will prevent her PC from going into sleep mode. Good Luck.
Oct 26, 2009 | Dell Dimension 4600 PC Desktop
My monitor is in sleep mode and I cannot get it out if it.
Sleep Sleep is a mode that the computer enters after being inactive for a set amount of time. Commonly, this mode will turn off a device or set it into a stand-by
Engergy star No data is lost when computer components enter a low-power mode, ... keyboard would get the computer out of this mode. Also see: Power Definitions, Sleep
This should wake your computer, Good Luck/Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion F1703 17" LCD Monitor
HP Pavillion dv6000 Vista notebook crashes when entering sleep mode
This is a common problem with HP Pavilion laptops, including mine. Check and make sure there are no non-OS programs running that are trying to control power settings (like a power monitor program running in the system/task tray) and then turning of hibernation in the POWER SETTINGS and then for all "WHEN I CLOSE LID" and "WHEN I PUSH THE SLEEP BUTTON" and "WHEN I PUSH THE POWER BUTTON" select DO NOTHING, then APPLY. Then SAVE SCHEME AS and choose any new name. This will disable all sleep modes forever, but at least you can get on with normal use.
If you are geeky, try going into the BIOS and DISABLING anything marked WAKE ON, and disabling anything having to do with automatic power features, and then try hibernating and so forth normally through the OS again. Sometimes this works if there are conflicting settings in the BIOS also trying to increase power efficiency.
Good luck...
Nov 08, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
