I set the oven to self-clean, and it did; but after completing the cycle, the oven refuses to unlock! I have tried unplugging it, disconnecting the breaker, pushing the clean cycle again, and every time, it beeps and flashes the error code. I just want my oven back!!!! How do I unlock the door?!
SOURCE: I tried to set my self-cleaning on my Electric
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: We used the self cleaning option on our Kenmore
SOURCE: Kenmore 95024 Electric Range The self clean cycle Door stuck shu
SOURCE: Kenmore self-cleaning range, display shows code E1-F2.
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
SOURCE: I have a Kenmore self cleaning electric range #
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.DGF$^%&*
